Zumo 660 Interface connection - Road Glide Forums
post #1 of 4 (permalink) Old 09-25-2012, 05:19 PM Thread Starter
b104396's Avatar
Have the HD 660 with interface connectivity. Usually I have voice command on mute but today was going to unknown area in traffic and figured I should have unit give turn by turn thru the radio or headset. Turned off the mute but nothing coming thru either the speakers or headset. When 660 is talking it cuts out the music but no voice commands. Hit the HK NAV button and it comes up stating NO NAV INTERFACE INSTALLED.
Drove to dealer and got deer in the headlight look. Will need to bring in and have diagnostics performed. Sounds expensive. Anyone else have this issue that got resolved?
2011 103" RGU Merlot Sunglo V&H Rounds, SERT, Fullsac X Pipe, SE/AC, SE255 cams,Brightass, IPOD Kit, Zumo 660, Hammock, Heritage Bars, Bag Guards, Tire Presssure Monitoring.
b104396 is offline
post #2 of 4 (permalink) Old 09-25-2012, 05:47 PM
Medic Tim's Avatar
Did you have the speaker switch in the proper position? I have had the same issue. The speaker switch needs to be in the middle or down position to hear the voice commands from the interface. One position plays through the radio and the other through your headset. If in the headset position the radio will stop playing while the voice commands are playing in the headset. Try changing the switch position.
Hope this helps.
2016 CVO Charcoal Slate/Carbon Dust
Medic Tim is offline
post #3 of 4 (permalink) Old 09-25-2012, 05:58 PM
bvanlente's Avatar
I have to do this on a very regular basis, take some dialetric grease and apply to the contacts on the back of the garmin and the connector. If not I will get different errors: Sometimes no music, other times I get searching for Sat and one error that says to upgrade satelite device. Apply liberally and you'll find, if like mine, it will cure most issues.
A design flaw IMO from Garmin (one a many).
Men fight for freedom, then they begin to accumulate laws to take it away from themselves. ~Author Unknown
bvanlente is offline
post #4 of 4 (permalink) Old 09-25-2012, 07:24 PM
Ditch's Avatar
If you have the interface instaled the voice comands come though the phone system if the volume is turned down on it you will not hear it.
Sent from my PC36100 using Motorcycle.com Free App
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
Garmin Zumo 660 RT wired up..... SEUGOT1 Aftermarket Accessories 10 04-03-2012 10:15 PM
Garmin Zumo 660/665 GPS Locking Mount HarleyCharley Equipment-RG 9 01-09-2012 07:50 PM
2011 RG CVO Zumo 660 Phone Intergration stewarrd Troubleshooting for Road Glides 26 06-18-2011 10:48 PM
Zumo 660 plumcrazeman Aftermarket Accessories 0 12-27-2009 10:49 AM
