665 XM Antenna - Road Glide Forums
 2Likes
post #1 of 14 (permalink) Old 10-03-2015, 10:24 PM Thread Starter
665 XM Antenna
I just installed the 665 and now trying to find the best spot for the antenna. I am trying to put it somewhere other than under the fairing so i can use it in the other vehicle. Itis the puck style non magnetic. Thanks in advance
GlideRide is offline
post #2 of 14 (permalink) Old 10-03-2015, 11:25 PM
dnschmpn's Avatar
I have a tech mount base for my Zumo that includes a spot for the base plate for the xm antenna. Works great.
Enjoy the Ride!
2013 RGU in Big Blue Pearl
dnschmpn is offline
post #3 of 14 (permalink) Old 10-04-2015, 12:03 AM Thread Starter
I was thinking about in the tour pak or saddlebag, was wondering if anyone has tried that
post #4 of 14 (permalink) Old 10-04-2015, 12:50 AM
I installed this one a few days ago and it works great!
RAM Marine Antenna Adapter Plate (Universal AMPs Hole Pattern)
Azblu is offline
post #5 of 14 (permalink) Old 10-04-2015, 07:48 AM
Ohiobellboy's Avatar
Is the antenna hard wired? If not, pick up a 2nd one online and mount one in the fairing and use the other one for other vehicles.
Smarty likes this.
A.K.A OBB
Ohiobellboy is offline
post #6 of 14 (permalink) Old 10-04-2015, 08:33 AM Thread Starter
I have the harley cradle on the left handle bar, the cables are run under the tank and the antenna plug is by the back of the tank on the left side
post #7 of 14 (permalink) Old 11-11-2015, 01:01 AM
You can't do this, the Antenna IS the SiriusXM unit.
I have my 665 in the Garmin motorcycle mount/integrated power cable etc. and that in an Iron Aces mount. I attached a Garmin 6-foot extension cable part number is 010-10617-02 to the wiring from the mount. I drilled a hole in the glove box large enough to run the wire into it. I used bubble wrap to fill the lower portion of the glove box so the antenna lies flat. Now you can transfer it to another vehicle or take it off the bike at night in the motel parking lot.
HoMa506 is offline
post #8 of 14 (permalink) Old 05-06-2016, 02:15 AM
I ran a Garmin Extension Cable through a rubber o-ring to prevent the cable from rubbing and fraying and then drilled a hole in the right glove box just large enough to fit the o-ring and cable. You can then use whatever you have lying around (packing peanuts, bubble wrap... etc) to fill the glove box to the point the antenna sits flat. Now you can plug or unplug the antenna anytime you want.
HoMa506 is offline
post #9 of 14 (permalink) Old 05-06-2016, 10:39 AM
Originally Posted by HoMa506 View Post
You can't do this, the Antenna IS the GPS unit.
Clarification. The antenna is not for GPS but for XM satellites. XM subscriptions are tied to the antenna not the device in this setup.
The 665 works just fine as a GPS without the antennae puck attached but there will be no XM.
Are you sure it is not magnetic? Mine is. I agonized over it's location and never found a suitable option other than just sticking it to the tank. I think my best option might have been to figure out how to stick it in the space above the radio but inside the windshield. Just never came up with a look that was clean enough to suit me. One benefit of that is being able to shift it around when signal gets blocked by me or the fairing.
Post pics if your figure out something cool.
ev780 is offline
post #10 of 14 (permalink) Old 05-06-2016, 11:04 AM
I've changes XM antennas a few times looking for better reception. This had zero effect on my subscription, which is tied to the XM receiver, not the antenna. For what it's worth, I get great reception with a home "clamshell" antenna velcroed to the inner fairing on top of the radio mount. Yes it's visible. No, I don't care.
SiriusXM Home Antenna for SiriusXM, XM and Sirius Satellite Radios Black NGHA1 - Best Buy
TomB. is offline
Zumo 665 with Xm and Bluetooth FLTRXXX Parts for Sale 0 04-08-2016 09:59 PM
Road Tech zumo 665 Mulit-Fit GPS Navigator with XM weetn Parts for Sale 0 06-15-2014 10:47 PM
2011 FLTRUSE with RT 660. Want to add 665 with XM Puck DAP525 Audio 3 06-04-2014 06:49 AM
Garmin Zumo 665 XM Radio- My Good Idea BDMastiff *General Road Glide Discussions/Pictures 6 10-05-2011 06:46 AM
XM antenna location ? spender9 Audio 3 06-12-2011 05:26 AM
