GPS Glare - Road Glide Forums
 7Likes
post #1 of 14 (permalink) Old 04-08-2016, 09:21 AM Thread Starter
SteveH's Avatar
GPS Glare
Has anybody found a solution for the glare on the 6 1/2 screen GPS?
SteveH is offline
post #2 of 14 (permalink) Old 04-08-2016, 10:38 AM
There is a high contrast option available now with the later releases of the Boombox firmware. Press the Info button on your right grip until the screen changes to a high contrast white theme... this does help a bit, but other than that, not that I know of.
When the glare's bad from the sun behind my back, I guess I just don't look at it... I'm more focused on how bad ass my silhouette looks to anyone in front of me... kinda like Clint Eastwood in The Outlaw Josey Wales - insert spaghetti western music here...
madmat, abigdog5 and Suprtrukr70 like this.
2015 Road Glide Special
caberto is offline
post #3 of 14 (permalink) Old 04-08-2016, 12:39 PM
seetiggergo's Avatar
Depending upon which GPS unit you have, you might be able to get a screen protector that will reduce the glare.
Hope this helps!!
Lindsey :0)
SteveH likes this.
'08 Harley Road Glide - Iron Aces Mount - Too many other upgrades to list!
seetiggergo is offline
post #4 of 14 (permalink) Old 04-09-2016, 12:14 PM
This works really well
GlareStomper - GPS Visors | Shades | Anti-Glare Hoods
Nevermind, I see you have the boom screen. Not sure if you could incorporate the glarestomper into that setup
tOSUSteve is offline
post #5 of 14 (permalink) Old 04-11-2016, 01:18 PM
PFWiz's Avatar
Hope this helps!!
Lindsey :0)
You guys do realize that they are talking about the HD Boom unit like what comes stock on a 2016 RGU right?
PFWiz is offline
post #6 of 14 (permalink) Old 04-11-2016, 06:02 PM
Gary R's Avatar
GPS Glare
Here's a glare shield for the new boom system.
http://www.priushood.com/sun-visor-h...nt-syst65.html
You can also diffuse the glare a fair amount by getting one of those pell and stick screen protectors for a iPad and cut it to fit. Get a rough texture one, not glossy. $10 at Walmart. I'd do both.
A hammer and/or duct tape also come to mind.
I'd used this. It helps some.
Gary R is offline
post #7 of 14 (permalink) Old 04-11-2016, 06:43 PM
Ohiobellboy's Avatar
Sun Visor Harley-Davidson 6.5 Boom! Box Infotainment system
Attachment 252506
I've got something like that now. I also put some on the speedo and tach. It cuts the glare and reflection down but that screen is still a washout if the sun is behind you.
A.K.A OBB
Ohiobellboy is offline
post #8 of 14 (permalink) Old 04-11-2016, 07:10 PM
Optimystic's Avatar
I just use the high contrast color option. Doesn't help with glare but makes it more visible in the daytime.
Optimystic is offline
post #9 of 14 (permalink) Old 04-12-2016, 10:07 PM
MatteGlide15's Avatar
I just ordered a NuShield dayvue screen protector for my 6.5 screen. I will provide feedback once I get it installed and test it out
MatteGlide15 is offline
post #10 of 14 (permalink) Old 04-23-2016, 06:27 PM
ButchS's Avatar
Memory and a good paper map---that's the key Oh and I do use my HD 660 GPS, but my mounting bracket allows for some up-down and left-right adjustments, so can get most of the glare off of it. But, memory is the key Or use a dry erase marker and write your directions on the windshield each day (doesn't hurt the windshield)--works pretty good, just a thought
ButchS is offline
GPS glare shield Flyboy1987 New Members Welcome Area 4 07-13-2018 06:50 AM
Blinded by the glare dgfltru *General Road Glide Discussions/Pictures 38 12-02-2016 05:52 PM
Stop GPS glare on 2016 RGU roadglide46 Audio 4 10-05-2015 06:53 PM
GPS sun glare solution.. bad86ta Equipment-RG 51 06-14-2014 10:47 AM
Glare or Griots Products Sparks Paint & Bodywork Section 5 07-13-2012 12:48 PM
