iPhone for Navigation - Road Glide Forums
post #1 of 23 (permalink) Old 12-23-2012, 06:57 AM Thread Starter
For those of you using the iPhone GPS, How is it working for you.
I have a Garmin 478 (marine GPS with turn by turn for highway) but Garmin's map updates have gotten to the point where they won't load due to lack of memory.
So instead of buying a stand alone GPS, I'm looking at going with the IPhone and using the ruggedized, waterproof case.
I'm looking for feedback as to how well it works and whether you have to use Bluetooth for good turn by turn nav. Thanks
Captain13 is offline
post #2 of 23 (permalink) Old 12-23-2012, 07:35 AM
Phil_FLTRX's Avatar
I use mine all of the time with the free mapquest app. Works great.
2011 Vivid Black FLTRX, 107" Rev Perf, Zippers Thundermax AT, Roland Sands Speed 7 AC, Iron Aces iPhone holder, 8" KW, V&H Duals & Black Widows, DDM HIDs, ARC 6.5's, S.E. ported heads, 30 tooth frt sprocket.
You never see a Harley parked outside of a Psychiatristís office, now do you.....
Phil_FLTRX is offline
post #3 of 23 (permalink) Old 12-23-2012, 07:47 AM
elbohead's Avatar
Google maps with turn by turn is now available for the iPhone and seems to work well. I have my phone mounted with the Iron Aces iPhone mount (forum sponsor) and an auxilliary plug into the radio. You can hear the turn by turn directions through the speakers easily. Another great GPS app is DRIVE by MotionX. I think it costs a few dollars and you have to pay extra for turn by turn, but it works great. You can listen to music and it'll lower the volume, give the direction and turn the music back up. Only thing bad about smart phone based GPS that I can see is, no phone signal=no GPS. Sattelite based units (Garmin, etc.) don't have that problem.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #4 of 23 (permalink) Old 12-23-2012, 07:55 AM
MikeMan's Avatar
+1 on the MotionX app for IPhone.
2010 FLTRX
MikeMan is offline
post #5 of 23 (permalink) Old 12-23-2012, 08:19 AM
Triplej's Avatar
I use my IPhone with the Garmin Navigon app paired with the Sena Blutooth headset and it works great. The GPS will do turn by turn and turns down the music and then back up again when it's done navigating.
As for the GPS not working when you lose phone signal I have not found this to be the case. Very few times have I noticed it actually losing its ability to navigate and then it has been very brief. Seems that has happened with every other stand alone GPS i have tried at one time are another.
With the Iron Aces mount it makes for a very clean set up that's easy to remove.
Triplej is offline
post #6 of 23 (permalink) Old 12-23-2012, 08:29 AM
Hullhorr's Avatar
I also use the Motion x on my I-phone with the Iron Aces mount. It works great. The only negative is the waterproofness if it rains.
2009 FLTR MOP
Hullhorr is offline
post #7 of 23 (permalink) Old 12-23-2012, 09:44 AM
laxinharley's Avatar
Yep. Same thing. I also have waze which is a free GPS app. Works great.
laxinharley is offline
post #8 of 23 (permalink) Old 12-23-2012, 10:13 AM
Admin
BillyBob's Avatar
Yep new google maps with iPhone 5 works great. Used it yesterday going to get rid of my garmin, it's never accurate anyway
BillyBob is offline
post #9 of 23 (permalink) Old 12-23-2012, 01:57 PM
Illiniroads's Avatar
Use MotionX as well without issues except battery drain.
2012 RGC BIG Blue Pearl SE Stage II 95hp 107tq
2011 RS-S Can Am Spyder 106hp 77tq
Illiniroads is offline
post #10 of 23 (permalink) Old 12-23-2012, 02:57 PM Thread Starter
Thanks, everyone. Looks like I will have to add an app for the turn by turn. Best buy has a waterproof case. I think it's called the Lifesaver. I also saw one on Gearz yesterday that is made of polished aluminum that actually screws together I have to find that one online.
Question about install with Boom Navigation Interface Module McGruder GPS 5 04-14-2014 03:09 PM
Sony DSX-MS60 - Music navigation HellInABucket Audio 16 02-25-2013 08:35 AM
Need advice on navigation app Rowdy *General Road Glide Discussions/Pictures 21 06-08-2011 09:59 AM
