Garmin 660 - Road Glide Forums
 3Likes
  • 1 Post By Mike U
  • 1 Post By seetiggergo
  • 1 Post By Mike U
post #1 of 9 (permalink) Old 09-10-2016, 01:32 PM Thread Starter
MASQUEDMANN's Avatar
Garmin 660
Hello all i just got a garmin 660lm, wondering how everyone has wired it to the bike. And where to run the wires. Trying to avoid lifting the tank but if i must i must.
Tia
Masque
MASQUEDMANN is offline
post #2 of 9 (permalink) Old 09-10-2016, 02:05 PM
Mike U's Avatar
Maurice, I have the same unit and I mounted it to the Iron Aces RG Mount and wired it into the AUX switch.
I did have to raise the tank to get the wiring run tho.
It's not really that hard to do.
Hope this helps Bro.
Mike U.
seetiggergo likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 9 (permalink) Old 09-10-2016, 02:21 PM Thread Starter
Thanks Mike
post #4 of 9 (permalink) Old 09-10-2016, 02:22 PM
Mike U's Avatar
You're very welcome Maurice.
USMC 1975-1977
Semper Fi!
post #5 of 9 (permalink) Old 09-10-2016, 02:25 PM Thread Starter
Sent you a pm
post #6 of 9 (permalink) Old 09-10-2016, 02:43 PM
Mike U's Avatar
I got them Bro.
Have a great day and we'll talk more tomorrow.
Mike U.
USMC 1975-1977
Semper Fi!
post #7 of 9 (permalink) Old 09-12-2016, 12:09 PM
seetiggergo's Avatar
Mike U.
Tia
Masque
@Mike U , thanks so much for making mention of our Road Glide Mount!!
@MASQUEDMANN ....just to add to what Mike had to say, I'd also consider one of our Supplemental 12v Power Points for running the power to your Zumo 660. As Mike eluded to, this 12v Power Point would allow you to control power to the 660 via the ACC Switch on the dash. The following link will take you to the product page on our website where you can read more about the 12v Power Point.
Supplemental 12v Power Point - Iron Aces Speed Shop
Hope this helps but certainly let me know if you have any other questions.
Lindsey :0)
Mike U likes this.
'08 Harley Road Glide - Iron Aces Mount - Too many other upgrades to list!
seetiggergo is offline
post #8 of 9 (permalink) Old 09-12-2016, 01:05 PM
Mike U's Avatar
Lindsey :0)
Lindsey, it's my pleasure mentioning the Iron Aces RG Mount.
It works excellent on my 2012 RG.
It's a very great mount and I also mentioned in my PM to MASQUEDMANN that you are a Member of Our Forum and Owner of Iron Aces Speed Shop and that you always take great care of All of Our Members when they purchase anything from you.
It's always a pleasure doing business with Iron Aces Speed Shop.
Mike U.
USMC 1975-1977
Semper Fi!
post #9 of 9 (permalink) Old 09-12-2016, 01:46 PM
skratch's Avatar
I also use the iron aces mount. but I added another swivel to it that allows me to tilt my 660 up/back/left/right as needed.
if you use the garmin wiring harness, you can run the aux plug to the audio input on your hk (this is obviously for 2013 and older), while running everything through the instrument nacelle and then down under the tank. removing the tank is easy, and there is a plastic channel under it. remove the lid, run your wiring, replace the lid. wiring is nice and protected. get the aux plug from iron aces, and you can plug into the aux plug under the seat and your mount will be powered by the aux switch on your dash.
it only takes a little longer to do it right, and then it's done and you won't have to do it again.
this first pic shows the swivel. $15 from amazon.
this pic shows the routing of the wiring. yes, the zip tie is blue. its what I had .... it would be very similar for a rushmore model, except you would have to purchase the additional aux input harness for the back of the infotainment and would actually be a cleaner install cause you wouldn't see this wire all the time. eventually, I will be sending my radio to iron cross audio and getting the rear aux input install done.
skratch is offline
Garmin Zumo 660 for sale LPrez Sold 9 08-15-2013 09:31 AM
WTB garmin 660 darty411 Wanted! (Buy or Trade) 1 06-14-2012 06:25 AM
Garmin Zumo 660 RT wired up..... SEsupply2 Aftermarket Accessories 10 04-03-2012 09:15 PM
Garmin Zumo 660/665 GPS Locking Mount HarleyCharley Equipment-RG 9 01-09-2012 06:50 PM
