GPS Bluetooth - Road Glide Forums
post #1 of 3 (permalink) Old 12-17-2016, 01:57 PM Thread Starter
GPS Bluetooth
I have a Road Tech Zumo 665 from my Ultra Limited that I am determined to use on my new (2017) Road Glide. Why? It's just the way I am.
It is mounted, and will be wired in soon. I have tried many times but can't get the Bluetooth communication established. The Infotainment GPS sees the Zumo and the Zumo sees the HD, but I can't get them to communicate. Any ideas???
Thanks ...Smoky
Smoky is offline
post #2 of 3 (permalink) Old 12-17-2016, 02:58 PM
skratch's Avatar
I don't think it works that way. pretty sure that the Bluetooth on the garmin is so that your phone will ring in through your gps, not so your gps will play via a Bluetooth receiver. to do what you want to do, hd sells a rear mount aux in plug.
http://www.harley-davidson.com/store...iary-input-kit
skratch is offline
post #3 of 3 (permalink) Old 12-18-2016, 07:43 AM
Post
What Scratch said it will not work in the configuration that you are attempting. However your in luck as you have the Harley branded Garmin so you can purchase the Auxiliary Input adapter from Harley that installs on the rear of the radio. You will have to wire it in. Once you have that the dealer will have to program your radio to see the Auxiliary input and name it, then you will be able to select it just like you would select AM or FM. Since it is a Road Tech it will interrupt what ever is playing on the radio and allow you to hear the turn prompts.
[email protected]
pilot is offline
Zumo 665 GPS with Bluetooth GliderRider GPS 3 06-17-2015 11:21 PM
Bluetooth with GPS & Phone BigWaterJim GPS 10 02-21-2014 08:20 PM
How to send sound from HK radio using Bluetooth to my Bluetooth helmut? bear25314 *General Road Glide Discussions/Pictures 2 08-16-2013 01:29 AM
J&M Bluetooth for cell and gps etc!! Bill H Audio 2 09-01-2012 05:56 AM
Which GPS sends voice directions to bluetooth ear piece? Black Sheep GPS 6 08-31-2012 10:35 PM
