how to remove power terminal on gps wires - Road Glide Forums
post #1 of 4 (permalink) Old 01-01-2017, 08:03 PM Thread Starter
I have looked everywhere and can't find a how to remove the connector on the Garmin GPS stock wires on my 2011 Fltruse. I am putting new bars on my bike and want to get the GPS wires off then back in the new bars and am stuck waiting to figure that one stinking terminal.
Anyone have a video of that terminal disassembly?
jethro_3 is offline
post #2 of 4 (permalink) Old 01-01-2017, 08:46 PM
perrykw's Avatar
Any way you can post a pic of it? I cut the harness on mine to internally wire and added a new connector, but you may be able to repin yours. If you can post a pic of the connector I may be able to help.
perrykw is offline
post #3 of 4 (permalink) Old 01-02-2017, 07:34 AM
Smile
If you are talking about the wire with the fuse holder then you will need to cut the fuse holder off. Its molded and you will not be able to remove the wire from the use holder.
Just cut the wire about 3 inched above the fuse holder and splice it back on when your ready.
[email protected]
pilot is offline
post #4 of 4 (permalink) Old 01-02-2017, 07:35 AM
Smile
If you are talking about the wire with the fuse holder then you will need to cut the fuse holder off. Its molded and you will not be able to remove the wire from the fuse holder.
[email protected]
pilot is offline
gray terminal lead nate99z Controls & Handlebars 4 08-02-2017 06:11 PM
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
12v terminal block help toogood8p Do-IT-Yourself 12 03-25-2015 10:09 AM
Terminal reference? Papi63 *General Road Glide Discussions/Pictures 3 10-26-2013 06:44 AM
Power Commander install/remove Mugs RG ECM/Fuel Management systems 2 07-24-2013 07:52 AM
