RAM Double Socket Swivel Arm - Road Glide Forums
post #1 of 7 (permalink) Old 03-10-2013, 11:43 AM Thread Starter
I decided to put my Garmin Nuvi 1450 GPS on the bike and when I ordered the new holder for the GPS I decided to try out the double socket swivel arm, the salesman said it was a fairly new product offered by RAM. It seems to be very adjustable and I can put the GPS just about in any position. Has anyone else tried this mounting arm and how do you like it?
post #2 of 7 (permalink) Old 03-11-2013, 12:45 PM Thread Starter
I put a 100 miles on the bike yesterday and this is my review of the double socket swivel arm by RAM Mounts. It works great when it comes to positioning the GPS to any position you like, but because the arm is around 6 inches long and you can position it in some cantilevered positions there seems to be some bounce to the GPS when the bike hits bumps or rough road which is understandable but the bounce doesn't make the GPS unreadable. On a scale of 1 to 10 I would give it a 9 due to the bounce, the cost is reasonable @ $16.84 + shipping.
post #3 of 7 (permalink) Old 03-12-2013, 03:00 PM
When I first bought my RGU I used the double ball from Ram MOunt and two short arms. I could not get the single arm mount to move far enough back for a good view while riding. That solved the viewing problem, but then with the double ball there was an increase in height. I added a detachable EZ Pass holder to the RAM mount. I'll have to go to their website and check out your set up; it may be shorter. And yes, you're right about the vibration. You have to really crank down on those handles to keep it tight.
Dracut, MA
MSgt USAF (RET)
2012 FLTRU Vivid Black
Husker is offline
post #4 of 7 (permalink) Old 03-12-2013, 10:40 PM
rageglide's Avatar
You can minimize some of the vibration by rotating the ball (mount on the bars), ~90 degrees and pivot the mount 90 degrees off the ball. In fact you could rotate everything around the bar somewhat to minimize the length of the arm. Pulling the weight closer to the bar. Maybe not explaining it well, but think of it as "wrapping" the mount around the bar vs sticking straight out. I run the straight Ram mount and tuck it in as tight as possible without any issues at all with vibration.
rageglide is offline
post #5 of 7 (permalink) Old 03-13-2013, 02:33 AM
I'm running the single Ram & have no problems.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #6 of 7 (permalink) Old 03-13-2013, 07:05 PM
wjco9's Avatar
Re: RAM Double Socket Swivel Arm
added this today it's called an aviation glare screen mount seems to work very well will see how it does after a few days of riding
Live to Ride
Ride to Eat
wjco9 is offline
post #7 of 7 (permalink) Old 03-13-2013, 11:05 PM Thread Starter
I have the short single RAM mount too but it will not give the positioning options that the double arm does. I would say it would be a trade off between positioning or stability.
RAM Handle Bar Mount kit and RAM arm HUTMO Miscellaneous for Sale 0 01-27-2016 10:01 PM
Keep Your Head On a Swivel!! 09Sharknose General Off-Topic Discussions 47 10-25-2015 10:38 AM
Socket size for fork caps x52gnr *General Road Glide Discussions/Pictures 1 03-02-2012 10:31 AM
Custom Mod - 12V Power Socket in Right Glove Box Tytanium Do-IT-Yourself 14 10-28-2011 12:03 PM
7mm 12 point socket for rear brakes?? Kobrak *General Road Glide Discussions/Pictures 7 04-02-2011 11:29 AM
