Garmin road tech 665 anntenna placement? - Road Glide Forums
post #1 of 4 (permalink) Old 08-30-2013, 02:41 PM Thread Starter
I know others on here have the same unit or the std garmin 665 with the XM antenna, so my guestion to you is : Where did you end up putting your antenna? I have the Madstad shield so that may play a part,but I have tried 3 different locations under the fairing and none have given me what I would consider consistent reception. From other blogs and forums it is beginning to sound like it may have to be mounted on the tour pack. suggestions please?
LNWLF is offline
post #2 of 4 (permalink) Old 09-18-2013, 08:55 PM
I mounted mine in the left fairing glovebox. Works great
Sent from Motorcycle.com App
Easy Glide is offline
post #3 of 4 (permalink) Old 09-19-2013, 05:38 PM
OldNerdGuy's Avatar
Harley makes a mount specifically for this antenna for the Road Glide. It is P/N 76000016. It mounts it up against the side of the radio. I have one, with the metal windshield trim, and have no issues with reception as long as there are no mountains blocking me.
OldNerdGuy is offline
post #4 of 4 (permalink) Old 10-25-2013, 09:29 PM
bootlegger61's Avatar
Magnetic Mount
Since I remove my Garmin quite frequently, I wanted something that was easy to take off, and found this from Harley. You can mount this on any metal surface. I mount it on my gas tank, and it has never failed me.
http://www.harley-davidson.com/store...-antenna-pouch
Currently Riding a 2015 Road Glide Special
bootlegger61 is offline
Road Tech Zumo 665 wiring questions Govdog76 GPS 10 05-20-2013 08:48 PM
Garmin XM Antenna Puck placement rrs49 Equipment-RG 10 06-03-2012 04:34 PM
Harley-Davidson Road Tech zūmo 660 and 665 Handlebar Mount Kit - Black longrides Classifieds Archive (3 months old+) 0 08-25-2011 09:48 AM
Trying to decided between Road Tech 660 and 665 G Audio 9 02-21-2011 08:30 PM
Deciding between Road Tech 660 & 665 - thoughts G *General Road Glide Discussions/Pictures 16 02-17-2011 12:55 PM
