Does anyone have photos of a Madstad from the front and sides, preferably a 14.5", with the holes drilled 1" higher than stock? I would like to see from the front and side if possible. Based on Madstads site I am between the 13" & 14.5" so thought if they look good with the holes drilled 1" high the 14.5" would be the best option since I like the looks with the shield in the lowered position the best. Thanks everyone.
In terms of function, it likely does not matter. With the short shield, the shield is raised higher with more of the metal bracket exposed. I like that look, which is my preference. Or, go for the taller shield, and it will cover more and probably all the metal bracket. The ultimate height of the top of the adjustable shield can be the same. So, what look do you want.
Tall - conservative look
Short - pushing the form follows edge.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
