Madstad "lift" effect - Road Glide Forums
post #1 of 41 (permalink) Old 02-13-2014, 05:01 PM Thread Starter
Installed a 13 inch Madstad on my RGC a few weeks ago. I certainly like it so far, as I have been battling with buffeting issues especially during the cooler months. It does seem to have helped with this issue. I have noticed however that the front end feels like it may be "lifting" at speeds over 80 mph. I was running a 12 inch Windsplitter before and the hips on the windshield tend to push the front end down at speed. The design of the Madstad does resemble a "wing" as air goes over and under it, so it may be a "feature" I will have to get used to. Just wondering if anyone else has experienced this sensation while using the Madstad windshield.
Thanks for the replies!
BadDog is offline
post #2 of 41 (permalink) Old 02-13-2014, 05:17 PM
Maybe a little but its not bad. Was it a windy day ?, I think the trade off is well worth it .
Some of the other wind deflectors out there work well with the Madstad too.
Big_gary is online now
post #3 of 41 (permalink) Old 02-13-2014, 08:00 PM
PFWiz's Avatar
No "lift" on mine at any speed under 110! Can't tell you what happens above 110... yet.
Are you sure that you don't have the bottom of the shield out to far vs the the top. That could cause lift.
PFWiz is offline
post #4 of 41 (permalink) Old 02-13-2014, 08:05 PM
themensh's Avatar
Send a message via Yahoo to themensh
WQings have a differant shape than the Madtad, I thing. A wing is designed for the air to have a 'longer trip over the wing, Vs. the air going under the wing.
I think I recall it being called 'Bernullis principle'...."As Velociti increases, pressure decreases".....also know as a "Venturi" effect.
(I learned this from watching "Big Bang Theory" on TV. LOL)
Chuck
Do not criticize someone until your have walked a mile in their shoes. That way, when they get pissed off, you are a mile away and have their shoes...
themensh is offline
post #5 of 41 (permalink) Old 02-13-2014, 08:10 PM Thread Starter
Smile
Wiz,
I have run it a different angles. Anywhere from 57 to 60 degrees. The front end just doesn't feel "planted" like it used to and I can only attribute it to the wing design of the Madstad. Just to rule out my imagination on this issue, thought I'd get some feedback from you guys...Thanks for the reply!
BadDog 2013 RGC
Stage 4 kit and lots of crap I really didn't need
BadDog is offline
post #6 of 41 (permalink) Old 02-13-2014, 10:38 PM
Are you tires in good condition, adequate pressure? May be a tire lost just enough air sometime after the new shield was installed.
grambo is offline
post #7 of 41 (permalink) Old 02-13-2014, 11:01 PM
direwolf's Avatar
Been running mine for over two years and never noticed the front end lifting up. I would think if anything the design would have more of a tendency to keep the front end down. JMO…
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #8 of 41 (permalink) Old 02-14-2014, 05:46 AM
I too have a slight lift above 90mph but I do agree the trade off is worth it. When I know I will be running hard I switch over to my KW shield.
concreteman is offline
post #9 of 41 (permalink) Old 02-14-2014, 06:21 AM
Ohiobellboy's Avatar
Maybe not lift but some much less wind on you that it feels lighter???
A.K.A OBB
Ohiobellboy is offline
post #10 of 41 (permalink) Old 02-14-2014, 06:47 AM
I would suggest that you bring the windshield out from the mounting shield a little. I had some lift issues and it was coming from the rear pressure (vacuum) because not enough air is coming under the base of the shield. Moving the shield out some will relieve that rear pressure on the shield.
Captain13 is offline
Should I get a jack lift or a table type lift MarkL *General Road Glide Discussions/Pictures 32 04-01-2017 10:08 PM
To Lift Or Not to Lift Texas Rapier *General Road Glide Discussions/Pictures 6 05-30-2016 09:03 PM
HF 1000lb lift table lift Blackbag1 Do-IT-Yourself 44 06-11-2015 06:49 PM
2010 revised fairing mount effect on windshields? GizmoGlide Windshields 44 07-07-2013 06:29 PM
New Hostile Fire pay changes now in effect 4getNo1 Active Military and Veteran's group 10 02-06-2012 03:47 PM
