Cee Bailey Noise - Road Glide Forums
post #1 of 7 (permalink) Old 04-26-2014, 08:25 PM Thread Starter
Cee Bailey Noise
My Cee bailey is noisy, it sounds like something might be loose. Is this normal, I mean I can live with it but if it can be fixed, I can do that too? Vibration sound
Cort Dog is offline
post #2 of 7 (permalink) Old 04-26-2014, 08:39 PM
Howardsternspenis's Avatar
Question Is it moving?
Does the windshield move when you're out riding around?
Maybe it just needs to be tightened up a little bit?
Did you get the Cee Baileys well nuts when you got your windshield? Supposedly, they're better than stock.
HSP
Howardsternspenis is offline
post #3 of 7 (permalink) Old 04-26-2014, 10:37 PM
My Wind Vest was noisy. but I think I left the well nuts a little loose.
grambo is offline
post #4 of 7 (permalink) Old 04-27-2014, 10:23 AM
crossbonesglide's Avatar
well nuts
When I ran a Cee Bailey I had better luck with HD wellnuts then I did with the CB wellnuts. The new HD wellnuts are larger than the old ones and will retake their original shape when placed in hot water. The CB wellnuts seem like one shot wonders. Tighten to the instructions directions, using an electric screw driver, and if you overtighten they become too deformed to reuse. They also seemed to push the windshield out more than I liked.
crossbonesglide is offline
post #5 of 7 (permalink) Old 04-27-2014, 12:23 PM
thedude's Avatar
Which CB are you running and do you have windshield trim? I use to run a CB Screamin Eagle Retro with the Yaffe trim. CB says you cant use that combo together but I decided to try it any way. I found out why they call it a Screamin Eagle. I just put some foam packing behind the trim and that eliminated the noise. Good Luck.
thedude is offline
post #6 of 7 (permalink) Old 04-29-2014, 12:10 PM Thread Starter
I have the 14" TRSSC Euro. I don't have trim and I believe I used the Harley screws and well nuts, I can't remember if it came with any. The are tight just not over tight, I did'nt want to damage the product.
Cort Dog is offline
post #7 of 7 (permalink) Old 04-30-2014, 09:38 AM
I have the same windshield but in 16". mine is totally quiet. yours should be as well. I have tried it with and without the oem trim. for me it comes out the same.
re-pete is offline
Cee Devil by Cee Bailey LARGECARTRANSPORT Windshields 6 07-16-2012 09:31 PM
FS Cee Bailey, Cee Glide 11" windshield pigfixer Sold 10 11-24-2011 03:33 PM
Cee Bailey's Cee Glide 14 Beachjeep Windshields 5 08-11-2011 01:04 AM
Cee Bailey's 13-inch Cee Glide on a 2005 63 340hp Windshields 13 04-09-2011 10:11 AM
