Madstad help... - Road Glide Forums
post #1 of 10 (permalink) Old 08-10-2014, 09:06 PM Thread Starter
Madstad help...
My interest is growing for this shield, but want to ensure I get the right size. I can't really tell how you can articulate the robo brackets so can any of you with the 11" and 13" set them in the lowest possible position and take a level measurement off the top of the radio housing to top of shield and post. I would truly appreciate it and thank you in advance...T
NCRG12 is offline
post #2 of 10 (permalink) Old 08-10-2014, 09:42 PM
Well I have a 14.5" shield on a 2006. I do not know the verticle height measurements at this time but I can tell you that at its lowest height it is lower than my 13" Windvest. At its highest setting I am looking through it. Good protection at the lowest with very minimal buffeting, just smooth wind. Exceptional protection at the highest. There is also a thread called vertical height data base that may be helpful to you.
grambo is offline
post #3 of 10 (permalink) Old 08-10-2014, 11:21 PM
Stickman81's Avatar
Greetings,
I measured my 13" a while back.
See my post, #11.
There may be some other information in there you could find informative.
Best of luck,
Jim
Jim
"Ride safe, have fun, wash hands often".
Current: '11 Road Glide Ultra. (3-9-13)
Stickman81 is offline
post #4 of 10 (permalink) Old 08-11-2014, 06:10 AM
piggs's Avatar
Originally Posted by Stickman81 View Post
Greetings,
See my post, #11.
Best of luck,
Jim
no input on the madstad height but stick, how bout a link , or the threads title..
there is a post #11 in many threads..
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #5 of 10 (permalink) Old 08-11-2014, 11:04 AM
ERod62's Avatar
Are you asking for the lowest set point heigh measurement from top of the radio?
If so here is the 13" at the lowest position measure from top of the faring above the radio.
Sent from Motorcycle.com App
ERod62 is offline
post #6 of 10 (permalink) Old 08-11-2014, 07:13 PM Thread Starter
Heigth
Attachment 139074
ERod62, thanks for the post, is it safe to say the 13" in it's lowest possible position rises around 6" above the top of the radio housing?
NCRG12 is offline
post #7 of 10 (permalink) Old 08-12-2014, 12:19 AM
Stickman81's Avatar
D'oh - Sorry.
https://www.roadglide.org/showthread....hlight=measure
(from the above link)
I just measured the MadStad as requested.
The following is what I came up with. YMMV.
I used a level across the top of the shield at about the center and used a tape measure from the top of the radio console to the bottom of the level.
Shield full down -
Tilt: forward = 7 inches.
Tilt: aft = 6.5 inches.
Shield full up -
Tilt: forward = 10 inches.
Tilt: aft = 8.5 inches.
Hope this helps,
Jim
Jim
post #8 of 10 (permalink) Old 08-12-2014, 01:52 AM
mitchdm's Avatar
The Magic of the Madstad is the lower the height it still works. I have an 11 and am thinking of getting to cut me one even shorter.
mitchdm is offline
post #9 of 10 (permalink) Old 08-12-2014, 09:39 AM
ERod62's Avatar
You got it.
ERod62 is offline
post #10 of 10 (permalink) Old 08-12-2014, 08:31 PM Thread Starter
D'oh - Sorry.
Shield full down -
Shield full up -
Hope this helps,
Jim
Thank you for the post Jim...
mitchdm, thanks for the info, any chance you could check those measurements with your 11" Madstad? Thanks...T
NCRG12 is offline
Madstad Help tarmac81 Windshields 23 10-26-2013 05:54 PM
REALLY close to getting 13" Madstad, help please bd1980 Windshields 7 08-14-2013 08:43 PM
Help from Madstad owners. 02heritage Windshields 5 10-23-2012 10:26 AM
How much dose madstad windshields help passengers?? Lee2012fltru Windshields 2 10-02-2012 09:25 AM
Madstad help maddogdrury Windshields 5 01-09-2012 08:33 PM
