Problems with Madstad - Road Glide Forums
post #1 of 31 (permalink) Old 05-16-2015, 10:17 PM Thread Starter
2004RoadGlide's Avatar
I'm having problems with my Madstad windshield so before I replace it I wanted to ask the forum to see what I might be doing wrong. First off I have to say that the Madstad does a fantastic job of eliminating turbulence directly in front of my helmet. The problem I'm having is with turbulence directly above my head. The turbulence shakes my helmet and is very annoying. I have tried all kinds of angles and heights. Not long after my model year Road Glide (2004) they made a change to the Road Glide where they rotated the fairing one or two degrees forward and I'm wondering if that could be the problem. I think I can still purchase the hardware to make that mod to my bike but I wanted to know if anyone else had that problem on the older Road Glides with the Madstad. I'm 5'9" but most of my height comes from above my waist and I have a fat head I guess because I wear an extra large helmet. I'm not sure of the height of Madstad I have but I just measured it and it looks like It's about 13" tall at the tallest points on the windshield if I lay a tape measure up and down along the front of the windshield. If I need to do the mod to rotate the fairing I will do that but I didn't want to do it unless I have to. Any help or suggestions are appreciated. Thanks.
2004RoadGlide is offline
post #2 of 31 (permalink) Old 05-16-2015, 10:28 PM
Try a set of HD crash bar wind baffles, and Sancho wings.
post #3 of 31 (permalink) Old 05-17-2015, 12:11 AM Thread Starter
I do have the HD crash bar or engine guard baffles installed. Will the Sancho's wings improve wind buffeting above my head?
post #4 of 31 (permalink) Old 05-17-2015, 06:39 AM
nsbohall's Avatar
Do you have the older mounting brackets or the Robo brackets? The Robo "might" give you a little more adjustment.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
post #5 of 31 (permalink) Old 05-17-2015, 07:10 AM
Marion's Avatar
I tried Snacho Wings...didn't do anything...
Marion is offline
post #6 of 31 (permalink) Old 05-17-2015, 07:35 AM
RGKen's Avatar
I have found that moving the outer shield brackets to the outer holes on the base brackets to create a larger gap between the shields make the difference. Also I angle the shield back towards me more than most say and the air is smooth. I am 6'1" and I run the 11" shield most of the time so I get plenty of air but not any buffeting.
2018 FLTRXS
RGKen is offline
post #7 of 31 (permalink) Old 05-17-2015, 07:35 AM
Yes, they will stop the air coming around the tank that rides up your body. They're the BEST wind protection baffle on the market.
post #8 of 31 (permalink) Old 05-17-2015, 07:49 AM
Have you tried contacting Madstad. When I called them, they have been very helpful. They may be able to help and may also know if changing the fairing angle would help.
Thuval is offline
post #9 of 31 (permalink) Old 05-17-2015, 08:02 AM
Bandit 7's Avatar
The old brackets which I have actually allow for more adjustment than the new style which I also have. What the new style does is allow you to make adjustments easier, faster and on the fly.
Bandit 7 is online now
post #10 of 31 (permalink) Old 05-17-2015, 08:15 AM
ichiban's Avatar
I set my shield at 58 degrees using a 11" set edge at nose height. air goes over my head riding solo. check your brackets. i am running with the deep robo brackets. gives a greater separation between the inner and outer shields. i am 5'8" with 1" lowered stock RGU seat. call Mark at Madstad
ichiban is offline
Denim Paint.....Any Problems? unclebuz *General Road Glide Discussions/Pictures 14 07-17-2011 05:33 PM
Fly wheel problems are a coming vontoughguy *General Road Glide Discussions/Pictures 6 10-31-2010 09:41 PM
Frustrating Problems fltrxdave *General Road Glide Discussions/Pictures 17 10-16-2010 11:42 AM
Harmon Karmon CD Problems - Help mtglide Troubleshooting for Road Glides 5 08-20-2010 04:53 PM
