Tour Glide windshield differences? - Road Glide Forums
post #1 of 7 (permalink) Old 08-12-2015, 10:38 PM Thread Starter
FRISCO67's Avatar
I have a 1979-'83 Tour glide fairing and need a windshield, but all I see is Tour Glide windshields from 1984-'95,does anyone know if the '84-'95 fit a '79-'83 fairing?
FRISCO67 is offline
post #2 of 7 (permalink) Old 08-12-2015, 11:32 PM
JacktheBagger's Avatar
My guess is yes it will fit , I had two TG's 1984 and 1988 , for many many years .
Here is the deal . If you pull up part numbers for 79-83 , you get the standard windshield ( 20" ) p/n 58009-80A and a 22" p/n 58016-80A ..
Pull up a part number for 1984 up and you get 58009-89 and 58016-89 .. The only way a -89 would work on my 84 is that there was a small change made somewhere , my 84 had to come with a -80A shield ..
The fairings are the same , I really don't know the diff between the -80A and -89
JtB
2011 Ultra
JacktheBagger is online now
post #3 of 7 (permalink) Old 08-13-2015, 12:10 AM Thread Starter
FRISCO67's Avatar
Thanks Jack, that's a big help,very much appreciated.
Cheers~Kim
FRISCO67 is offline
post #4 of 7 (permalink) Old 08-13-2015, 11:13 AM
No it won't! I have an '82 tour glide and it is a different screen.
Clearview shields made one special for mine. It took several weeks to get it.
Motorcycle Windshields & Custom Windscreens | Clearview Shields
Here is a screen shot of the body of my order.
File Type: jpg Screen Shot 2015-08-13 at 9.09.15 AM.jpg (78.3 KB, 14 views)
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #5 of 7 (permalink) Old 08-13-2015, 07:25 PM Thread Starter
FRISCO67's Avatar
Thanks AzHogRider, I copied your statement from Clearview that may be the way to go but that is a little pricey, that's like $215 Canadian for a hunk of plexiglass
FRISCO67 is offline
post #6 of 7 (permalink) Old 08-14-2015, 07:50 AM
It is the only place I could find one for the '82. Really it was a custom order and they don't stock them but cut it to order. I suspect they have a CNC setup and just rip through them when they have some time.
This email was sent to you to inform you of the beginning stages of production of your order.
1. This first stage is what we call prefabrication, which is the cutting and edge conditioning of the 2 dimensional shape of the screen.
2. Upon completion of the first stage it then moves to the second stage which is thermoforming, where the contour or shape is set.
3. The final stage is the installation of any accessories, lower screen masking, final inspections and packaging for shipment.
You will be notified again of the status of your order at the beginning of the second stage and from UPS The evening of the departure date including a tracking number of your shipment.
It is more than just cutting plexiglass.
@ Jack I think it is the bolt locations at least are different.
post #7 of 7 (permalink) Old 08-14-2015, 01:08 PM
bolts are only diff I could imagine and I wouldn't have thought of that if you had not said it , the fairing is the same and both shields have eight bolts ..
Oh the joys of old iron
JtB
2011 Ultra
Tour Glide vs Road Glide - Differences riccardo_21 *General Road Glide Discussions/Pictures 38 03-07-2017 07:54 PM
09-10-11 Fairing Wire Harness Differences robertg Troubleshooting for Road Glides 4 10-18-2014 10:31 PM
what r the differences betweed junk runner jr *General Road Glide Discussions/Pictures 16 11-21-2011 07:05 PM
'11/'12 RGU differences? StriderJim *General Road Glide Discussions/Pictures 30 11-06-2011 08:01 AM
Differences between 09 vs 11 RGs Lu *General Road Glide Discussions/Pictures 21 08-26-2010 11:39 PM
