13" dark Madstad. This is gonna take some getting used to. - Road Glide Forums
 2Likes
post #1 of 28 (permalink) Old 09-18-2015, 08:11 PM Thread Starter
HellInABucket's Avatar
I've got it set at 60 degrees, the recommended starting point per the instructions.
Its all the way vertical, which might change after I get a chance to test ride it, but it seems about as tall as my 13" LRS Mako.
HellInABucket is online now
post #2 of 28 (permalink) Old 09-18-2015, 08:31 PM
I got mine set at about 57 . The same as the base. Have you test rode it yet ?
RGKen likes this.
post #3 of 28 (permalink) Old 09-18-2015, 08:52 PM Thread Starter
I havent. I'll try to get out tomorrow afternoon, looks like rain in the morning here.
I'm 5 foot 9.5, I had it at the tallest setting, but when I sat on it I was definitely looking through it so I slid it down a bit.
We shall see.
post #4 of 28 (permalink) Old 09-18-2015, 09:18 PM
the88virgnian's Avatar
You'll have it all the way down by the end of your testing, with a huge smile on your face. And as for the angle, I've never measured mine. Never seems to be an issue, no matter what angle!
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #5 of 28 (permalink) Old 09-18-2015, 09:18 PM
RonC26's Avatar
I've got mine at about the same angle as the base too, and just look over the top of the shield. Don't be afraid to play with it a little to see what you like. I spent about 30 minutes one evening buzzing up & back on the interstate and made about 4 adjustments. Seemed pretty good & haven't touched again (except to tighten nuts occasionally ). Everyone seems to set them slightly differently. When you get it close I predict you'll be very satisfied.
Good luck!
Ron
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #6 of 28 (permalink) Old 09-18-2015, 09:42 PM Thread Starter
Ok, what size is the lock nut on the bottom that allows you to slide the shield up/down? Seems like 10MM is the only one that will fit.
I'm going to have to run out tomorrow morning to get a 3/8 spinner for the hex socket so I can tighten those lower 2 bolts once I get it set up the way I want it.
post #7 of 28 (permalink) Old 09-18-2015, 09:49 PM
idahointrudr's Avatar
I have mine set same as base. Its all the way down.
I have 60,000 miles on this shield. Works great.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #8 of 28 (permalink) Old 09-18-2015, 09:51 PM
You just need to turn the black knob (2) and the window will slide up and down.
post #9 of 28 (permalink) Old 09-18-2015, 09:51 PM
the older mounting bracketts had 4 holes to change angle of shield.they now have 1 set.you may have to drill 2 more to make shield more vertical.at least i did. with the current holes on new madstad it is about the same as a mako shield.
diesel5 is offline
post #10 of 28 (permalink) Old 09-18-2015, 09:56 PM Thread Starter
Right, I get that, but there is a nut/bolt on the pivot point as well, I want to snug that up. Seems like its a tad loose and might rattle.
Madstad 13" dark gray windshield only NEW Bill H Parts for Sale 2 08-09-2014 05:47 PM
Madstad 13" Dark vondutchga Parts for Sale 8 07-29-2014 09:55 PM
REALLY close to getting 13" Madstad, help please bd1980 Windshields 7 08-14-2013 07:43 PM
13" dark Madstad bulldog68 Windshields 4 07-19-2013 03:24 PM
I'm gonna do it, I'm gonna do it.... Howardsternspenis Intake and Exhaust 15 07-06-2013 04:28 PM
