question on windvest installation - Road Glide Forums
 5Likes
post #1 of 14 (permalink) Old 02-09-2016, 05:22 PM Thread Starter
cookie114's Avatar
I've got a new 10in windvest in the mail and was wondering do I have to use the rubber windshield trim with it? I just removed a 8 in Klock werks and it was installed without the trim.
cookie114 is offline
post #2 of 14 (permalink) Old 02-09-2016, 06:03 PM
hilltoptim's Avatar
windvest
FYI, I'm running a 14" windvest. I didn't use the trim with mine.
However I have 2 large black faucet washers at each fastner between the windshield and fairing. This will let some air through which reduces the negative pressure on the back side of the windshield. Reduces the buffeting.
cookie114 likes this.
hilltoptim is offline
post #3 of 14 (permalink) Old 02-09-2016, 06:41 PM
jeff338wm's Avatar
I've not seen that before but makes sense. Can you dimension these large faucet washers for me, diameter and thickness? How much gap have you created? Is the windshield firm or have a lot of flex?
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #4 of 14 (permalink) Old 02-09-2016, 08:12 PM
I have a 10 inch on my 2015 withe factory screws and washers. At this point all is good. 10000 miles. The shield itself works well for rider and passenger, after trying 4 other ones. The dark smoke looks good on the black bike.
Drampy is offline
post #5 of 14 (permalink) Old 02-11-2016, 07:11 AM
Like to hear and see more about this. Im in to try it.
phillyfan1 is offline
post #6 of 14 (permalink) Old 02-11-2016, 07:46 AM
hilltoptim's Avatar
The faucet washers are probably 1/2" to 5/8" in outside diameter, and 1/8" to 3/16" max thickness . I'm guessing at this point.
I believe that the larger outside diameter will give your shield better support.
I used the OEM hardware ( screws and wellnuts) with no problem. If the center hole of the washer is small just drill it out.
As you know faucet washers are typically a black hard rubber type material. They blend right in with the bike and windshield.
No issues whatsoever with stability. Probably have 40k miles on my bike with this set up.
This set up slightly simulates the madstadt? Windshield but looks better in my opinion.
post #7 of 14 (permalink) Old 02-11-2016, 07:54 AM
Thanks for the reply. Bike has some parts at the powder coater now, perfect time to pick some up and try.
post #8 of 14 (permalink) Old 02-12-2016, 05:44 PM
jeff338wm's Avatar
I'm for giving this a try, but one last question. I have a bunch of faucet washers but they all are flat on one side and convex on the other, are yours shaped similar? I'm thinkin' flat on both sides would be better.
post #9 of 14 (permalink) Old 02-12-2016, 08:53 PM
You can buy the rubber W/S seal at the dealer. It has some adhesive for the W/S to stay in place. Apx $20. I'd suggest you replace all the hardware with new. Do a search & you'll find some helpful info on replacing your W/S & hardware.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #10 of 14 (permalink) Old 02-12-2016, 09:35 PM
RICKLB58's Avatar
I am going to try Tim's way 1st seems similar and simpler but here is a link of another way some have done a little different.
https://www.roadglide.org/23-windshie...-wellnuts.html
2012 RGU, Thunder Max tuner, V/H power duals, Stage one, DayMakers, 12 inch F47 Malos, custom gages, and some extra chrome.
RICKLB58 is offline
Windvest Installation pskorupa Windshields 4 05-16-2013 12:53 PM
Yet ANOTHER Tour Pack installation question d-roadglidr Lighting 5 11-28-2012 04:32 PM
Windvest Installation Tips outlawjessejames Windshields 11 03-09-2012 08:41 AM
lowering spring installation question junk runner jr Suspensions 2 02-18-2012 08:42 PM
Intercom installation question DRAFT1 Equipment-RG 1 06-22-2011 06:56 PM
