scrape fix? - Road Glide Forums
post #1 of 5 (permalink) Old 05-19-2016, 04:56 PM Thread Starter
cloud's Avatar
scrape fix?
Ok......so the Road Glide stock windscreen has that black section at the lower portion of the shield........
Mine has been scraped from multiple removal/installation
I have seen this on many Road Glides......
Is there any sort of fix? I know the best thing is to avoid scraping it......but once it is scraped. Is there a way to hide it or cover it up.
Anyone?
Cut N Shoot Hog Chapter, Patriot Guard Rider
'05 FLTRI, Stage 1 setup and gear driven cams installed.
'12 FLTRU, Stage 1 setup, cams and tuner installed.
cloud is offline
post #2 of 5 (permalink) Old 05-19-2016, 05:00 PM
Anyone?
Sand the inside with 400 gt sandpaper and repaint it.
post #3 of 5 (permalink) Old 05-19-2016, 06:06 PM Thread Starter
cloud's Avatar
Is that paint? I thought it was some sort of vinyl coating or something.
Thanks
cloud is offline
post #4 of 5 (permalink) Old 05-19-2016, 06:23 PM
Thanks
It should be flat paint . It really doesn't matter though. Mask off what your going to sand . Sand out the scratches . Clean & remask ,find a plastic friendly paint and spray 3 or 4 light coats. Use a flat or satin sheen.
post #5 of 5 (permalink) Old 05-19-2016, 06:39 PM
Remove the shield
Make pattern against the inner fairing outside
Of area you want blacked, like on the inner with paper of the area you want it to look like on the shield
Take that pattern and flip it to the inside the shield, like if you use a black film
something like that
reds4 is offline
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 06:26 PM
New exhaust that does not scrape in the twisties justaguy Intake and Exhaust 12 07-16-2013 01:12 PM
Scrape Reduction Efforts bikepsych Suspensions 16 06-10-2012 05:41 AM
For those that scrape footboards religiously, I have a question Gadgetech *General Road Glide Discussions/Pictures 10 12-20-2011 07:25 AM
Monster Ovals, anyone ever scrape em? RIDERED67 Intake and Exhaust 20 09-27-2011 10:47 AM
