Any hope for removing these scratches? - Road Glide Forums
 8Likes
post #1 of 17 (permalink) Old 01-26-2017, 12:10 PM Thread Starter
I got a good deal on a used Windvest windshield for my bike, but it has a bunch of pretty harsh scratches on it. As you'll see in the photos, these aren't your normal swirls from regular riding.
Any suggestions as to what might work (if anything) to bring this shield back to life? I've heard that the Novus 1-2-3 system is pretty good. It is my understanding that Windvest uses Lexan for their shields.
macabra11 is offline
post #2 of 17 (permalink) Old 01-26-2017, 12:11 PM Thread Starter
Here is another shot of some more scratches.
post #3 of 17 (permalink) Old 01-26-2017, 12:19 PM
Jacksprat56's Avatar
Wish I could help you man, but have not ran into that issue. Someone will come along that has "the" answer; that's what's so great about this forum. Good luck.
Jacksprat56 is offline
post #4 of 17 (permalink) Old 01-26-2017, 12:49 PM
WTFranz's Avatar
I suggest contacting John at Freedom Shields [email protected]
He seems like a pretty great guy and they mfg their own windshields. I'm sure if you explain that you understand it's not his product but that you value his experience and knowledge and you bought it used people in the industry can do wonders with their experience.
I think he follows the board and positive complements are always good for business.
Swomack and Jacksprat56 like this.
WTFranz is offline
post #5 of 17 (permalink) Old 01-26-2017, 02:35 PM
Dragon Dude's Avatar
They have some video's on U tube on how to fix scratched windshields, worth a try.
Jacksprat56 likes this.
Dragon Dude is offline
post #6 of 17 (permalink) Old 01-26-2017, 02:53 PM Thread Starter
Yeah I was watching a few of those and I think I'm going to attempt to use the Novus system and some buffing pads. Saw another technique that used a heat gun to sort of melt the material, but that scares me a little and I doubt it would remove scratches as big as what I have.
I'm not really in a big hurry as riding season is a loooooooong ways away still But this will give me a nice little winter project to do inside while drinking a beer by the fire.
If anyone else has any other suggestions, please let me know! Thanks all!
post #7 of 17 (permalink) Old 01-26-2017, 07:45 PM
I have had good luck with the Novus scratch and then polish. It may not take them all the way out but it will make an improvement. Might take a few or more applications. Don't be afraid to apply some pressure.
Good luck.
thealien is offline
post #8 of 17 (permalink) Old 01-27-2017, 07:11 AM
I would say that there isn't any chance of removing the scratches to the point where it looks like a new windshield. You can use the Novus scratch remover but if the scratches are too deep it will not remove them, you may be able to make the windshield look somewhat better though. Give it a try what you got to lose.
macabra11 likes this.
post #9 of 17 (permalink) Old 01-27-2017, 09:07 AM
Paul's Road Glide's Avatar
I will actually go against this comment but it does require a bit of work and most people just chock it up and buy a new one. But I know for a fact you can make it look like a brand new shield. Just requires patience and acquiring skill as you go.
You will need a can of spray called VHT nightshade. Basically a spray on tint and a can of VHT clear coat. Some sand paper of varying grits (no heavy grit for this job. Stay above 800 grit) and one small bottle of mequiar's plastic polish.
I used to do this all the time to darken the turn signal lenses of trucks and cars and when done it looked like a brand new from the factory lens cover but no cover, it was the actual housing. Man they came out so good. Anyways, I digress.
The idea is to sand down the scratched area starting with the 800 but you'll want to sand the whole thing. Yep the whole enchilada if you want it to look even. BTW always use water (wet sanding) when doing this. Once the whole thing is uniformly dulled out sometimes if the scratches are really deep you made to start or go back with a 400 grit but always follow with 800. Start wet sanding with the 1000 grit. Remember it will always look dull until you spray the VHT and clear coat. after a good sanding with the 1000, rinse really good and check for any deep scratches still present. If you see any go back with the 800 on those spots and follow with the 1000.
Once you are pleased and you no longer see deep lines then continue with a 1500 grit until its nice and smooth. So now that you have done all that clean with dish soap and rinse well. Try to set it somewhere with no debris blowing around.
THis is were your skill has to improve within a few passes. Spray the vht onto the shield at a very mechanical form. meaning if you are going to spray 6-10 away from surface do not fan. Move you spray pattern perpendicular to your surface as if attached to it by some kind of tether. Basically if you start spraying in the middle 10" away your ends should only be 10" away and not 12-13" away on the ends.
It may require 2 passes. follow instructions on can. I failed to mention that VHT will darken your shield if you prefer not to darken then you'll need to just spray the clear coat.
On to the how the VHT or clear removes the cloudy or foggy look. The spray media actually fills in at the microscopic level all the fine scratches that the 1500 sanding left behind. basically looks cloudy to us and not actual hard scratches. Once those two or either media is applied and allowed to cure you then go back and sand with 1000, 1500 and lastly 2000. all wet sanded. Once you have attained your 2000 grit wet sand (still cloudy) you apply some turtles buffing compound and buff the hell out of it with your hand or get you a buffing wheel and buff it. Be careful not to linger in one spot for too long. You'll burn the clear. Once that is done apply some dabs of the meguiars plastic polish and your good to go.
If done right it's going to look better than new.
with all this said (typed and read) some people opt to just buy a brand new one. I include myself in that now! good luck, have fun.
Paul's Road Glide is offline
post #10 of 17 (permalink) Old 01-27-2017, 10:59 AM
BlazingSaddle's Avatar
How picky are you over those scratches? If so picky you would take the time, effort, and pay for materials to do as Paul's Road Glide suggested to make it look brand new, (and you might or might not have the skill set to get "like new" results), you've got your work cut out for you. For the time and materials you would have to invest, for about $50 and cost of shipping, you could get a brand new LRS. Better yet, sell the windvest and put that money towards an LRS and now you really got yourself a smokin' deal. Bang for the buck, mine makes me smile. If you're not that picky, and scratches aren't and won't reflect light in your line of sight, use some of the suggestions here and call the scratches "character".
BlazingSaddle is offline
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 06:01 PM
I hope I really love these 2+2's JacktheBagger Controls & Handlebars 2 05-08-2012 11:10 AM
Primary Cover Scratches BlackBetty11 *General Road Glide Discussions/Pictures 3 10-18-2011 11:31 AM
Scratches strangeglass Paint & Bodywork Section 3 08-29-2011 08:12 PM
fine scratches in windshield mdjr47 Windshields 9 04-26-2011 11:12 AM
