getting screws back into the well nuts - Road Glide Forums
 3Likes
  • 1 Post By thealien
  • 1 Post By PBSTN
  • 1 Post By phillyfan1
post #1 of 7 (permalink) Old 05-23-2017, 07:32 PM Thread Starter
On my 08 RG . Every time I take the windscreen off it is a pain or impossible to get screws 2 and four back in . I just purchased another screen and it is even tougher . It is like the screws arent long enough . I believe I will try longer ones but is there an easy way to do this ? Thanks in advance for your insight to my issue . Mark
MarkL is offline
post #2 of 7 (permalink) Old 05-23-2017, 08:40 PM
snarley53's Avatar
some one on here you can find aftermarket windshield mounting hardware that comes with longer screws and heavy duty inserts they are worth the money, i got a set included when i bought my freedom shield.
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #3 of 7 (permalink) Old 05-23-2017, 11:05 PM
UT_Larry's Avatar
With the well nuts that were on my 91 FXR when a year or more old did not line up correctly due to the rubber being distorted, probably from me over tightening them. I recommend changing them. MadStad has some that the heads are oversized to prevent them from getting pushed all the way into the fairing.
UT_Larry is offline
post #4 of 7 (permalink) Old 05-24-2017, 07:37 AM
I used to screw the well nuts onto the screws through the windshield. Not tight just snug so its touching the windshield and not bulging. I would then just push the well nuts into the holes windshield and all. Then tighten as normal. I always kept a handful on hand and would replace them before the got all hard.
MarkL likes this.
thealien is offline
post #5 of 7 (permalink) Old 05-24-2017, 09:41 AM
PBSTN's Avatar
What he said^
MarkL likes this.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is offline
post #6 of 7 (permalink) Old 05-24-2017, 01:02 PM
Originally Posted by PBSTN View Post
What he said^
X2
MarkL likes this.
phillyfan1 is offline
post #7 of 7 (permalink) Old 05-25-2017, 06:04 PM Thread Starter
Well , I didn`t believe you but desperation made me try it anyway . Worked like a charm , like super easy . Thanks ! Mark
MarkL is offline
source for fairing screws and windshield screws...chrome? Kobrak *General Road Glide Discussions/Pictures 11 02-07-2013 11:51 PM
Well Nuts Size Mason417 Windshields 13 01-25-2013 06:20 PM
Well Nuts are you F****ING kidding me HarleyArcher Windshields 31 03-25-2012 08:47 PM
Fnin well nuts METIME Windshields 23 01-10-2012 01:21 PM
Well nuts - How tight? Ozoneman Windshields 12 05-12-2011 06:45 PM
