Madstad whistle? - Road Glide Forums
post #1 of 14 (permalink) Old 09-30-2017, 04:05 PM Thread Starter
DanHappy's Avatar
Madstad whistle?
All Madstad owners,
Whenever I put the shield up all the way, I get a wind noise. The sound is like if you ride in a car with all the widows close but one, and that one is open a very small crack. And only when I am doing 40 - 60. Lower I don't hear it and faster and the wind noise is louder. With it down I don't hear it.
Any else get this and what did you do to stop it?
DanHappy is offline
post #2 of 14 (permalink) Old 09-30-2017, 06:01 PM
RonC26's Avatar
Never heard it, but I hardly ever adjust my shield, and it's not all the way up.
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #3 of 14 (permalink) Old 09-30-2017, 06:39 PM
UT_Larry's Avatar
15 RG 9" MadStad. No issues at any settings.
UT_Larry is offline
post #4 of 14 (permalink) Old 10-01-2017, 07:09 AM
Originally Posted by DanHappy View Post
All Madstad owners,
Had the whistle years ago when I first got the Madstad 13". While playing with the angle to find the sweet spot. It would whistle when the angle was to flat (shield tipped back toward me too much). I found it works best at pretty much the same angle as the base and then adjust the height for how much air or rain protection is needed. I used to obsess over trying to get it just right using an angle finder app on my cell phone. Now I just eye ball it and go. Results are the same.
BlueBagger12 likes this.
2012 FLTRX, vivid black
sometimer is online now
post #5 of 14 (permalink) Old 10-01-2017, 08:57 AM
All Madstad owners,
Play with the angle.
post #6 of 14 (permalink) Old 10-01-2017, 09:32 AM
Shemp's Avatar
Check the edges, especially the bottom and feel if it has a straight cut with a sharp edge or more round. Mine had a whistle and after rolling a snake of masking tape and sticking it along the bottom of the shield to test it went away. I ended up carefully filing a more round edge along the bottom of the shield and it took care of it
2011 RGU Merlot/Sunglo, Daymakers, 13" Madstad dark grey windshield, LED tourpac lights, SE RT/SE AC, Bassani Road Rage 2/1 pipes, Wild 1 10" mini apes, Street Glide fascia.
Miles of twisting mountain roads with no guardrails!
Shemp is offline
post #7 of 14 (permalink) Old 10-01-2017, 09:34 AM
madmat's Avatar
Dan, maybe try dropping 1/2 -1"? Or changing angle a bit, I used to use 59-60 degrees.
Maybe double check mtg hardware is snug?
Is the whistle definitely coming from the windshield or maybe something else on fairing?
18 RGS Bonneville Salt Pearl
madmat is offline
post #8 of 14 (permalink) Old 10-02-2017, 07:40 AM Thread Starter
DanHappy's Avatar
All tight. I even thought that it was torqued a little to one side, so I loosened all the hardware and tightened all in rotation partern. Didn't help.
I tried adjusting it down a little and it didn't help. I have to pushed the farthest forward right now. May try pulling it back a little. So far I like it all the way forward but if I have to move it bak to get rid of the whistle... or I might try to switch to the other shield. I don't remember it doing it. I don't remember having it up all the way either.... hmmm...
Yes also I went over everything else and didn't see anything out of place. I thought of putting on my old shield to see if it whistled. Then I could rule out the madstad. But haven't did that yet.
DanHappy is offline
post #9 of 14 (permalink) Old 10-02-2017, 07:53 AM Thread Starter
DanHappy's Avatar
Originally Posted by Shemp View Post
...after rolling a snake of masking tape and sticking it along the bottom of the shield to test it went away. I ended up carefully filing a more round edge along the bottom of the shield and it took care of it
What do you mean by that. I had an idea and you might be saying the same thing.
DanHappy is offline
post #10 of 14 (permalink) Old 10-02-2017, 11:11 AM
Shemp's Avatar
get out a piece of masking tape about the length of the bottom of your shield and roll it up length wise. Or even a piece of door trim would work. Something to disrupt the flow of air across the bottom of the shield. a strip of door trim form your local auto store and you could use it later to replace the fairing trim if need be
Shemp is offline
Madstad whistle? HellInABucket Windshields 19 07-19-2018 07:47 AM
Madstad whistle please help tarmac81 Windshields 1 09-28-2015 08:33 AM
Whistle Sound getarpicker Intake and Exhaust 10 06-30-2013 10:41 AM
Madstad Whistle RG-Hawk Windshields 12 03-16-2013 11:01 PM
squeel - whistle in front end Boogitybob *General Road Glide Discussions/Pictures 9 04-08-2011 12:12 AM
