bad vibration after installing short windshield - Road Glide Forums
post #1 of 8 (permalink) Old 04-29-2013, 11:04 AM Thread Starter
Looking for a little advice.... I apologize if this is redundant as I looked for info and couldn't find any on this subject. New guy, looking for some help.
i have a 2004 RG that I recently changed the windshield from the factory original to a HD OEM 4" windshield. After I replaced it and fired the bike up, I had a NASTY vibration between the top of the inner fairing and the windshield/outer fairing. If I put pressure on the inner fairing above the radio it helps a bit..
My question is has anyone else had this problem and what solution(s) did you do to fix it? or any ideas from anyone?
Thank you in advance.
-Rassy
2004 Road Glide
rassy is offline
post #2 of 8 (permalink) Old 05-06-2013, 05:30 PM
piggs's Avatar
I'd think it has to be a misalignment (windshield/fareing)and/or something not being tight enough. you only take out what? 5 screws? or try putting the stock one back on, for comparison.
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #3 of 8 (permalink) Old 05-06-2013, 06:20 PM
Sound like you didn't get the outer and inner fairing aligned properly.
post #4 of 8 (permalink) Old 05-06-2013, 06:23 PM
zemo1017's Avatar
Welcome to the Tank from a displaced Hoosier in West Alabama.
Make sure that the well nuts are tight. Have that same WS but have never experienced that situation.
zemo1017 is offline
post #5 of 8 (permalink) Old 05-06-2013, 06:47 PM
RedneckMedic66's Avatar
I would have to agree and say your outer was not put back on right last time.
GLIDE OR DIE!!
RedneckMedic66 is offline
post #6 of 8 (permalink) Old 05-07-2013, 10:34 AM Thread Starter
Thanks! Ill double check the outer fairing... I just bought the bike last year, so Im guessing the prior owner had taken it off before.
-Rassy
2004 Road Glide
rassy is offline
post #7 of 8 (permalink) Old 05-07-2013, 02:29 PM
Wellnuts are cheap, if compressed get new and right lenght, radio bracket(ck links on here), remember that lil windshield is a deflector, sometimes to your face. And the gasket right. If it wasn't doing it before what changed?
reds4 is offline
post #8 of 8 (permalink) Old 05-07-2013, 05:38 PM
Go to the dealer and look at the new bikes and maybe take a pic to compare when you get home. The gaps are very important to get closed up properly on the fairing.
Tags
2004 , vibration , windshield
103 vibration above 3000 rpm after cams? baldwookie Engine Related 22 06-17-2016 06:17 PM
Bad engine vibration at idle carlspeed Engine Related 19 11-28-2015 01:35 PM
Bad vibration slickskot Audio 8 02-10-2013 05:16 PM
I'm short are you short? WhoaD00DHD General Off-Topic Discussions 30 10-17-2011 09:28 PM
bad vibration on the decel!!! Help!!! shimo Troubleshooting for Road Glides 12 05-31-2011 05:29 PM
