Madstad users - Road Glide Forums
 19Likes
post #1 of 25 (permalink) Old 03-08-2018, 06:02 AM Thread Starter
Madstad users
I'm going to buy a Madstad shield but I'm hung up on the size, 12" or 14". I'm 5-11, 32" inseam and use an airhawk pad 100% of the time. I currently use a 13" LRS shield and it rides right around my chin height and I'm happy with that. Madstad states that if I get the 12" I'd operate it at its highest adjustment to mimic what I have. Finally my question. If I get the 14" do I get the 3" adjustability they talk about in both directions? Can I drop it 3" lower than 14" and 3" higher also? Is madstad worth it?
Sent from my SAMSUNG-SM-G930A using Tapatalk
bkgabby is offline
post #2 of 25 (permalink) Old 03-08-2018, 06:18 AM
HellInABucket's Avatar
I'm struggling with the same choices you are. I had a Madstad 13 on my 13 FLTRU, I loved it. Now I must choose between 12 and 14. I think because I'm a bit shorter than you are (5'-9"), I'm probably going to get a 12 and hope I can adjust it up a bit. I think these shields are definitely worth it. On my '13, I could smoke a cigar at 60MPH. Cant do that now with my LRS shield on my '17, I get hit in the face with ashes, sometimes hot. Not good. I'm assuming that I'll be able to do this on my '17 with a Madstad, that the aerodynamics of the new fairing haven't changed enough to preclude cigar smoking.
As for your other questions, I'd suggest another conversation with Madstad.
bkgabby likes this.
HellInABucket is offline
post #3 of 25 (permalink) Old 03-08-2018, 06:40 AM
RGKen's Avatar
I am 6'1" and had both 11" and 13" outer shields for my 2012 and ran the 11" 90% of the time. Even though there was more air felt with the 11" it was smooth air and was a very pleasant ride. I only used the 13" in colder temps on longer rides. I would go for the shorter shield and ask Mark if when buy the shield if you can swap the outer out for the taller one if the shorter one is not working for you. I think he was doing that for a while. The other factor is if you ride 2 up and your passengers head is above yours they would be more comfortable with the taller shield. If you have the Rushmore RG I still think the 12" would be fine even for the passenger.
bkgabby likes this.
2018 FLTRXS
RGKen is online now
post #4 of 25 (permalink) Old 03-08-2018, 06:41 AM
bosshogg123's Avatar
Madstad users
The Madstad is definitely worth it!
First: Is your Glide a 13-under or Rushmore? I’m 5’10 with a 29” inseam and had a 13” Madstad on my former 13 RGU. With your longer legs I would probably recommend the 12” normally but with The Airhawk pad the 14” might be the better choice. On the Rushmore I would probably lean toward a little sshorter to the 12”... you’re in a tough spot and could go either way...
bkgabby likes this.
bosshogg123 is offline
post #5 of 25 (permalink) Old 03-08-2018, 07:04 AM
Mike U's Avatar
I'm 5'-10" with a 32" inseam and running a Madstad 11" Extra Dark Gray On my 2012 Custom and love it.
For those interested, I just received an email from them and they are having a sale to save 20%.
Promo Code: MADSPRING20
VALID THROUGH MIDNIGHT 3/11/18
I hope this helps anyone looking for a Great Windshield.
Mike U.
bkgabby likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #6 of 25 (permalink) Old 03-08-2018, 07:58 AM
Morningwood's Avatar
I had a Madstad on my last bike. I believe the 3" of adjustment is total. 1.5" in either direction from center.
bkgabby likes this.
Morningwood is offline
post #7 of 25 (permalink) Old 03-08-2018, 06:25 PM Thread Starter
It's a '17 roadglide ultra.. Sorry I left that out.
bkgabby is offline
post #8 of 25 (permalink) Old 03-08-2018, 07:03 PM
Mike U.
Thanks , just used this!
post #9 of 25 (permalink) Old 03-08-2018, 07:50 PM
Mike U's Avatar
You're welcome Bro!
Glad you got to use it.
I hope you like Your Madstad as much as I do.
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
post #10 of 25 (permalink) Old 03-08-2018, 07:53 PM
mastergunnera8's Avatar
What seat are you on? and then an airhawk on top?...
mastergunnera8 is offline
Question for madstad users wjco9 Windshields 6 03-15-2014 10:16 AM
? for madstad users JJSW1283 Windshields 1 04-20-2012 06:14 AM
iPhone, Blackberry, Droid, Ipod Touch users.. DreamRider General Off-Topic Discussions 4 03-01-2011 10:42 AM
Q for Garmin Zumo Users Shrug Aftermarket Accessories 12 12-27-2010 12:38 PM
For all you not so vain GPS users : JacktheBagger Do-IT-Yourself 2 05-11-2010 07:11 PM
