How to internally wire handlebars (especially bars with sharp bends) - Road Glide Forums
post #1 of 9 (permalink) Old 10-07-2009, 12:33 PM
The Infamous Sharknose
Guest
Posts: n/a
Exclamation How to internally wire handlebars (especially bars with sharp bends)
Run heavy string through the bars (using a vacuum or tie a small nut and let gravity pull it though). Make sure you have plenty of string hanging out the hand control end to tape the entire bundle of wires.
Bundle the wires tightly with tape. If you have 13 wires bundle 6 wires together and bundle 7 wires together (2 SEPERATE BUNDLES). This makes pulling the bundles through with the many bagger wires much easier.
Tape the bundled wires tightly to the string. (THE ENTIRE LENGTH OF THE BUNDLE NOT JUST A COUPLE OF INCHES AS IT WILL PULL THE STRING OUT IF BINDING OCCURS). If this doesn't work....tie a slip loop on the string and loop around about 12 inches up the bundle and tape tightly again.
Lubricate the inside of bars with Dawn. It's a messy gooey, black job but it makes it a lot easier.
Now...pull the string through the bars while someone is pushing the bundle and string through the hole where the controls are. REMEMBER, ITS A PUSH/PULL EFFECT. PUSH-BUNCH, PULL SLACK, PUSH-BUNCH, PULL SLACK.
Now take the bars outside with the wires hanging out the bottom of the bars. Wash the soap off the wires. Take laquer thinner and clean the residue of each wire individually.
Finish, drink beer and thank me later....
It's not easy but remember, PIMPIN aint EASY.
post #2 of 9 (permalink) Old 10-07-2009, 12:40 PM
rippedglide
Guest
Posts: n/a
Yeah - use a half hitch on the wires! The string will break before the knot comes undone..
post #3 of 9 (permalink) Old 10-10-2009, 06:44 PM
Sonar_Chris's Avatar
Make sure the holes in the bars are absolutely burr less. take a piece of 250 grit sand paper and clean around the holes in the bars to ensure you will not nick or scratch any of the wires.
Sonar_Chris is offline
post #4 of 9 (permalink) Old 10-21-2009, 06:08 AM
dklanecky's Avatar
Good advice and suggestions. I always cut the electrical cords off "dead applicances" and save the wiring for this type of fishing. Amazing just how many times I've used individual wire stands out of an old 30' long vaccum cleaner cord.
Never throw anything out and my garage looks like it too.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #5 of 9 (permalink) Old 12-08-2010, 12:05 AM
Cool Day 2
Yesterday I pulled my ride apart, did some wire work I wanted and broke her down for the 12" Monkey bar install.
Day 2 I started the wire pull. Now pay close attention, after purchasing wire extention kit from yaffie. I noticed no TBW kit, called Paul and in his own arrogant way let me know it was not needed, I asked why he sold it to me? Well dude was right I pulled all the wires using all the stock covers, had my wife help keep pressure on wires as I fished, took a few hours with some WD and KY on right, dry for left. Reroughted clutch and brake line. To see how it handles without extending. I'll keep ya up to date. Now remember I'm a disablied dude with a bad back and bumb legs. If I can do it Anyone can. Oh yea, did I mention I got anger issues? Well didn't have to lose my cool. Merry Christmas all and God Bless you all, your bro Frodoe
Frodoe is offline
post #6 of 9 (permalink) Old 12-08-2010, 06:57 AM
ncbeast's Avatar
Frodoe, just curious why you got the extention? Paul has told me several time through email that the stock wires and cables are long enough to go up to 12"?
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #7 of 9 (permalink) Old 12-08-2010, 01:47 PM
RWB427's Avatar
I used a broken throttle cable and it worked great. I guess that was one good thing that came out of my broken throttle cable back in the spring .
RWB427 is offline
post #8 of 9 (permalink) Old 12-13-2010, 09:48 PM
If you hot some home electrical wire around the house, strip it and use the ground wire, works great!
Shane (From Washington)
2010 Road Glide Custom
Axtell 107 (10.6-1 Compression), Pro Street Heads by Dewey, TMAN 590 cams, S&S Roller Rockers, Woods Directional Lifters, Revolution Performance EMS, D&D Boss Fatcat, HD Heavy Breather, Alpine IDA-305s head unit, Boston Acoustic Pro 60SE Speakers, Alpine PDX 2.150 Amp. 116 HP/128 TQ
Various chrome and black bits......
"I've Got A Cobra Snake As A Necktie"
Garcou is offline
post #9 of 9 (permalink) Old 12-16-2010, 11:25 AM
Yaffe said I need it
Yaffe said that I was going to have to have it, after calling about TBW tune changed?
Frodoe is offline
6 Bends Harley vs. Black Widow What a joke chriscalabro *General Road Glide Discussions/Pictures 30 12-23-2016 07:57 AM
Not running wires internally? firehouse18 Controls & Handlebars 26 01-01-2013 06:34 PM
100% internally wired frost204 Controls & Handlebars 5 03-05-2012 08:48 PM
Running wires internally on Heritage bars x52gnr Controls & Handlebars 3 04-22-2011 11:53 AM
