13 inch bagger apes by cyclesmithe - Road Glide Forums
post #1 of 9 (permalink) Old 07-07-2010, 04:49 PM Thread Starter
just bought them and am not shure how much more clutch cable of brake line or fbw i might need any thoughts
2008 FLTR 105th Anniversary
2006 FXDBI (the kids ride)
2002 FXDX (my everyday)
BAGDRAGGER is offline
post #2 of 9 (permalink) Old 07-07-2010, 04:58 PM
Neano62's Avatar
08 TBW,... you should be fine. Even w/clutch and brake line.
[/IMG]
Neano62 is offline
post #3 of 9 (permalink) Old 07-08-2010, 12:54 AM
dikdark's Avatar
Neano's right, I believe 15" is max without adding onto cable etc.
07 RG Vivid Black
FLHX fascia
Stage 1, SE pipes DS baffles,
+2 Sweepers, chrome quickly fading to black
dikdark is offline
post #4 of 9 (permalink) Old 07-12-2010, 08:42 AM
MassHD's Avatar
Please post pic's when your done. I had these on my 08 SG and loved them.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #5 of 9 (permalink) Old 07-15-2010, 09:08 AM
I would like to see what they look like. I have a 2000 RG and I am thinking about installing ape hangers on mine but limited on funds so if they work without having to extend the brake lines or clutch cable it will be easier to convince the wife to let me swap them out.
HarleyB13 is offline
post #6 of 9 (permalink) Old 07-15-2010, 03:54 PM
MassHD's Avatar
Wires you are all set on the length. I had abs so my brake would have been diff compared to you. On the clutch I when with a +6 and that was to much. Might be able to squeeze the clutch in without changing it out. What I would do is install the bars and see if you need the clutch. You can order one while you F around with the internal wires.
MassHD is offline
post #7 of 9 (permalink) Old 07-19-2010, 12:09 AM
CCRydah's Avatar
Yep!........ I gotta see those pics when its done!
"That CC Guy"
2008 105th Anniversary "Tiger Shark" Road Glide
CCRydah is offline
post #8 of 9 (permalink) Old 07-20-2010, 05:11 PM
G.I.Mike's Avatar
Pics!
I agree! Pics please! I am wanting to install the same on my 09 so let us know what u run into (hopefully they bolt right on!)
2009 FLTR: SERT / blk 2-1 Thunderheader / Stage II / Chopped Tourpack / Kuryakyn sissybar / 14" Outlawz / Ness Turnsignals / 'Windshield of the day' / Love Jugs thermal management
G.I.Mike is offline
post #9 of 9 (permalink) Old 07-21-2010, 06:02 PM
slowglide2989's Avatar
i would say 14" is the max on the cables, but i guess it depends on which tape measure the manufacturer used. I have 14" santees and i only extended a few wires that were probably ok. Ill run things to the limit, with in being safe ofcourse but they are about maxed out i wouldnt go bigger.
Mines and 2010.
slowglide2989 is offline
12 inch shock 13 inch FXSTBRIDER Suspensions 11 08-06-2014 12:42 PM
Burly 1.25 inch Riser Drag Bar 13 inch Pullback Coolblue Controls & Handlebars 0 07-23-2014 12:14 PM
Bagger Werx apes fosterp Controls & Handlebars 6 10-12-2011 07:36 AM
Bagger apes h-donut Controls & Handlebars 11 09-02-2010 05:44 AM
