Why are handlebar vendor measurements so unreliable? The ANSWER! - Road Glide Forums
post #1 of 4 (permalink) Old 07-09-2010, 05:21 AM Thread Starter
4getNo1's Avatar
We simply have no reliable comparative measurements we can use. Just consider how some vendors measure "Pull Back" and "Height"
Harley Davidson says "Pull Back" is the distance from the centerline of the base tubing to the centerline of the grip-end tubing when the rising section of the bars is pressed up against a wall.
Harley:
Flanders uses "Height", not "Rise", and says "Height" is the distance from the leading edge of the clamp area tubing to the trailing edge of the grip area tubing when the grip area is pressed up against the ceiling.
Flanders: http://www.sideroadcycles.com/Americ...r_Options.html
...and now the most interesting of these examples - Wild Ones.
Wild Ones says "Pull Back" is the distance between the leading edge of the clamp area tubing to the trailing edge of the grip area tubing when the rising section of the bars is aligned with your scoot's neck angle/triple tree.
Wild Ones: http://www.wild1inc.com/chubbydimensions.html
WOW! Therefore you can modify you own "Pull Back" (and "Rise") if you own a set of Wild Ones. All you need to do is roll your bars FWD or back a bit.
Neat huh!
2013 FLTRX, Candy Orange
4getNo1 is offline
post #2 of 4 (permalink) Old 07-09-2010, 09:52 AM
I agree, I have gone thru many sets of bars looking for the right pullback and its soooooo hard to determine what to get by looking at catalog! Ended up with Wild1 16" apes and rolled them forward a bit. Spent lots of money on bars!!!! have 2 sets of 16"apes for sale if anyone is looking..;-))
pittz5 is offline
post #3 of 4 (permalink) Old 07-09-2010, 11:46 AM
Harley328's Avatar
Bars
I'm Looking what do you have?
Harley328 is offline
post #4 of 4 (permalink) Old 07-09-2010, 01:56 PM
I have a set of LA Choppers Muthafers that have 8.5" pullback and are black. and a set of Drag Specialities Chrome that have 10" pullback. Both arw TBW and 1.25". Mutherfers are very expensive and were on bike a week. Id sell for 200 and the chrome are fairly cheap, id sell those for 90.00
pittz5 is offline
2015 oem handlebar measurements fyi ynotbmester Controls & Handlebars 6 07-06-2015 11:33 PM
Why can't I get a straight answer? Brianu1 ECM/Fuel Management systems 10 06-16-2014 06:00 PM
Need Tour Pak measurements with brackets installed ironmark *General Road Glide Discussions/Pictures 3 01-24-2012 09:20 PM
Why? Why? Why? CMS *General Road Glide Discussions/Pictures 16 04-11-2011 01:46 PM
Here are Measurements of RG vs. Heritage Bars G Controls & Handlebars 5 01-30-2011 07:17 AM
