Internal Clutch and Throttle? - Road Glide Forums
post #1 of 10 (permalink) Old 07-12-2010, 12:58 PM Thread Starter
ncbeast's Avatar
Thinking of new bars and would love to go about 14". Ran accross this site http://www.stylinproducts.com/Hellbent%20Bars.htm and you can go as high as you want and new controls and everything ran internally, clutch and throttle too for about $1300? Seems like a pretty good deal but a couple of bad reviews that I have seen on the other site but no good ones?
I have not seen anyone else offering these? If this is no good might just get the 10" Monkey's and use the stock clutch and throttle....
I will send the company an email with a few questions and see if and how they respond.
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #2 of 10 (permalink) Old 07-12-2010, 08:48 PM
Neano62's Avatar
Yo Beast, COOL LOOKN SH!T. I have seen these Bars in a magazine or to on different bikes. Most Impressive w/everything ran Internally.
[/IMG]
Neano62 is offline
post #3 of 10 (permalink) Old 07-14-2010, 06:09 AM Thread Starter
ncbeast's Avatar
bump.........
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #4 of 10 (permalink) Old 07-14-2010, 07:03 AM
watchdog's Avatar
My brother has bars similar to those on his custom , for a really clean look even the master cylinders are internal , but the price was around $1600 and you only get 3 switches on each bar , no good if you have stereo and cruise.
Live everyday like it's your last.
watchdog is offline
post #5 of 10 (permalink) Old 07-14-2010, 07:21 AM
2010 FLTRX's Avatar
That setup is not really an internal clutch (internal clutch is a twist grip with cable inside the bar, ala Exile Cycles), it's just a hydraulic clutch plumbed through the bars. Still a neat idea, but you'd have to convert your trans to a hydraulic throwout bearing.
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #6 of 10 (permalink) Old 07-14-2010, 07:45 AM
watchdog's Avatar
He has a baker 6 speed. Not sure if its cable or hydraulic. It doesn't have a twist clutch' the left grip is the high/low beam switch. Front brake master cylinder is inside the bars. Very small gauge wires coming out of bars at bottom have to be hooked up to selonoids ( quite a few of them) to make everything work. he also had internal brakeline run inside the forkleg to a front caliper built into the forkleg.
watchdog is offline
post #7 of 10 (permalink) Old 07-14-2010, 08:26 AM
2010 FLTRX's Avatar
Sounds neat. My reply was about the setup in the first post, not yours.
post #8 of 10 (permalink) Old 07-14-2010, 12:42 PM Thread Starter
ncbeast's Avatar
This is from the website I posted above....
100% Internal features:
All parts made in U.S.A.
LESS IS BETTER, All cables, wires, lines 100% Internal for a true clean custom look.
Factory wiring harness for Plug & Play assembly, no soldering no cutting wires.
Not a KIT 100% assembled and tested ready for install.
All production bars available in either 1 1/4" diameter, or Stylin's Massive 1 1/2" diameter.
Switch housings include 6 switches for factory operation, our new housings accommodate cruise control and stereo.
Our Custom made "Hellbent Series" 1 1/2" diameter bars are custom made to customers specifications, Our most comfortable bend the "Relaxed Bend" allows your wrists to be straight forward and not angled like most production bars. Production time for Custom bars is approximately 10-14 working days.
Does not say anything about doing anything else?
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #9 of 10 (permalink) Old 07-21-2010, 06:05 PM
slowglide2989's Avatar
Hawg halters has a line of bars that are all internal with new controls.. Scared to ask how much though.
slowglide2989 is offline
post #10 of 10 (permalink) Old 07-21-2010, 06:24 PM
harley75's Avatar
Stay far away from stylin products!!!
75 Superglide
04 Texas Chopper
10 RGC
harley75 is offline
Internal Clutch / Brake Lines Bevis Controls & Handlebars 0 07-23-2017 08:40 PM
Very loud clank when shifting or getting on throttle or letting off throttle Callahan69 Engine Related 28 11-14-2016 01:09 PM
Clutch Wiz vs Burley easy clutch Trak350 *General Road Glide Discussions/Pictures 14 03-11-2014 09:21 AM
Internal Wiring - cut and solder vs. connector pins Stray Mutt Controls & Handlebars 53 02-23-2013 06:22 AM
New Paughco apes for FBW and internal wiring 4getNo1 Controls & Handlebars 32 01-20-2011 08:39 AM
