to cut or not to cut - Road Glide Forums
post #1 of 7 (permalink) Old 03-05-2012, 07:29 PM Thread Starter
Having an issue and my pist apes have me pist lol. I took the connector apart, shrinked everything good and tight and i have a metal blob at the end as all the connectors line up perfectly! i cant get them to make the turn, i ordered extensions and the wires will come out of the bars (17") so i could solder the end on it. anyway the inch that's rigid is whats killing me.
2011 Road Glide Ultra
72 Shovel
68 shovel 40 over denvers....
84 ZL900
2009 Busa
mroach is offline
post #2 of 7 (permalink) Old 03-05-2012, 08:00 PM
Nozzleman 216's Avatar
Which is why I am cutting and not pisting with the pins
I don't mind soldering and since I have to extend the wires anyhow (have 17's coming too) I am cutting them and adding on. I actually enjoy soldering. A few beers and the iPod makes it a little more than a tolerable process.
Captain, Coshocton Fire Dept.
IAFF Local 216 Secretary/Treasurer
2008 Mirage Orange Road Glide
Nozzleman 216 is offline
post #3 of 7 (permalink) Old 03-05-2012, 08:01 PM
You are pulling them through the bars with something (like a piece of utility wire), right? Sometimes turning the bundle like a corkscrew at the grip end with one hand while you pull out the hole at the clamp with the other helps.
I had to lengthen mine, too, by soldering but I did that before I put them through the bar. I still pulled it through pins and all.
SickRick is offline
post #4 of 7 (permalink) Old 03-05-2012, 08:09 PM Thread Starter
thanks, i decided the frustration wasn't worth it, stagger cut them, hooked em up and right on through plenty out the bottom so ill solder my extensions on and done. Probably trust my solder better than a connector anyway.
spent an hour trying to make the first corner, pulled all the way through in 15 mins...
72 Shovel
84 ZL900
2009 Busa
mroach is offline
post #5 of 7 (permalink) Old 03-06-2012, 10:51 AM
Good to hear. One thing I am debating is staggering the cuts. I did this with my Street Glide but had to as there was not enough wire to pull through the bars. I am thinking I can cut near the plug ends and pull through then just extend. Sure there will be clump where all the wires are soldered, but they won't be in the bars so I am not sure what the harm would be not staggering.
post #6 of 7 (permalink) Old 03-06-2012, 12:05 PM
Mcrider996's Avatar
I ended up doing the same thing after multiple failed attempts of getting the pins past the 2 sharp corners of my bars. It took me a little while to get all the solder and heat shrink done but it came out good and everything has worked great so far! Took me all of 15-20 mins to get them through the bars after stagger cutting the wires......
2009 FLTR 96", Custom denim Black paint.........always a work in progress
2004 1200C (hers)
"I'm not good........but I'm fast....."
Mcrider996 is offline
post #7 of 7 (permalink) Old 03-06-2012, 07:17 PM Thread Starter
i used weed eater line, taped up each wire about a foot and a half apart lubed it all and worked it through undid each wire as it came through and kept working it, super fast without the connectors. Just soldered on the left side extensions, will do the other side tomorrow. then on to the stereo oh fun.
72 Shovel
84 ZL900
2009 Busa
mroach is offline
Contrast Cut VS Platinum Cut RhinoHD Wheels and Tires 23 02-03-2014 10:27 PM
Install was not that bad..Alpine and J&M not a bad team Sixnine68 Audio 10 01-31-2014 04:28 PM
air lite owners cut the mesh out or not creed *General Road Glide Discussions/Pictures 4 11-13-2012 06:30 PM
Not One, Not Two, But... Andyman *General Road Glide Discussions/Pictures 4 04-21-2012 09:01 PM
