Lowering Handlebars? - Road Glide Forums
post #1 of 9 (permalink) Old 08-06-2010, 07:52 AM Thread Starter
joke's Avatar
Doing an 800 mile trip and would like a little less reach to my bars - If I just loosen the handlebars and drop them, say, an inch, will that hurt anything? Like clearing the tank, fairing, etc? Will the bars be any closer??
2009 Mirage Orange
joke is offline
post #2 of 9 (permalink) Old 08-06-2010, 09:23 AM
EZMotoTim's Avatar
Originally Posted by joke View Post
Doing an 800 mile trip and would like a little less reach to my bars - If I just loosen the handlebars and drop them, say, an inch, will that hurt anything? Like clearing the tank, fairing, etc? [B]Will the bars be any closer?? [/B
I did just what you are asking - I loosened the bars and rolled them toward me a bit. It didn't hurt anything. As for clearances, you just have to test that yourself. Adjust the bars, tighten the screws, turn the wheel lock to lock.
After making the adjustment I went on a 5700 mile trip. When I got back I installed the Heritage Style bars. That should tell you something. (see my post on the installation.)
EZMotoTim is offline
post #3 of 9 (permalink) Old 08-06-2010, 09:23 AM
DED HD's Avatar
Are they angled with the forks now?
I have my 2010 RG Bars pulled back quite a bit more than the angle of the front forks and it helps me reach them as I am only 5'6". Problem now is because they are so low, i get the in between the shoulder blade pain. Kind of a strain to have my arms down low, while looking up. Taller bars with more pullback are in my future.
'10 Red Custom:
DED HD is offline
post #4 of 9 (permalink) Old 08-06-2010, 06:36 PM
dklanecky's Avatar
I angled mine back exactly like your describing,and it removed all need for new bars, and that was 22k miles ago. I still like rolled back just a bit.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #5 of 9 (permalink) Old 08-06-2010, 08:07 PM
buzzman_45011's Avatar
Ok how do you do this? I wouldn't mind pushing mine a bit forward. I have very long arms. Where are the bolts to adjust them?
2010 Road Glide Custom
buzzman_45011 is online now
post #6 of 9 (permalink) Old 08-09-2010, 05:31 PM Thread Starter
joke's Avatar
Well I did them Saturday, easy to do - just remove bezel (2 screws) and expose the top bolts of the handlebars clamp (loosen just those two), mark original set up and measure to some set points, lower bars and remeasure. I lowered mine about 1/2" which moved the measured point 1/2" forward. If you lower them too much they will hit the center console. 3 screws on each control pod to loosen and adjust brake and clutch levers. Rode about 75 miles and will be getting Heritage or WO bars after I finish this upcoming trip. Somehow I knew that... But was hoping!
2009 Mirage Orange
joke is offline
post #7 of 9 (permalink) Old 08-09-2010, 09:39 PM
triple buzz's Avatar
lowering mine did not help with shoulder pain. Didn't make it any worst, but no gains for the time it took. I read every post on here trying to find what works best for the 6+ footers. The bars are my only gripe with my RGC.
triple buzz is offline
post #8 of 9 (permalink) Old 08-09-2010, 10:00 PM
joke, i replaced mine with heritage bars too. the hardest part of the entire install, truly, was reinstalling the damn outer fairing! the throttle by wire swap is simple, just gotta find the plug!
ilmanzo31 is offline
post #9 of 9 (permalink) Old 08-10-2010, 08:26 AM Thread Starter
joke's Avatar
I should have done this when I had the front off to put the new legs on but I've had the fairing off so many times now it's a snap. Had I known how easy the bars were to replace...now I know.
2009 Mirage Orange
joke is offline
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 12:09 PM
throttle cable handlebars and tbw handlebars Swagzilla Controls & Handlebars 2 01-30-2012 07:30 PM
lowering kits???? 3FEETUNDER Aftermarket Accessories 28 01-07-2011 07:00 PM
2010 rear lowering kit jjyoung *General Road Glide Discussions/Pictures 9 07-03-2010 08:12 AM
Lowering the Glide joke *General Road Glide Discussions/Pictures 17 02-07-2010 02:35 PM
