no need for apes! check out these bars! - Road Glide Forums
post #1 of 60 (permalink) Old 08-11-2010, 09:27 PM Thread Starter
gabbyduffy's Avatar
Risers on a 2010 roadglide. this set up rocks, I can change the hieght of my bars by changing the risers or adding riser extentions to find that sweet spot.
gabbyduffy is offline
post #2 of 60 (permalink) Old 08-11-2010, 09:35 PM Thread Starter
gabbyduffy's Avatar
2010 glide with risers. photos of riding position.
this set up really works out for me.
post #3 of 60 (permalink) Old 08-11-2010, 09:41 PM Thread Starter
gabbyduffy's Avatar
2010 glide with risers more photos
+2 roadglide handle bars and 6 inch risers.
post #4 of 60 (permalink) Old 08-11-2010, 10:17 PM
OK I'll Bite
How and where? I cant see over my wide shoulders. and are those factory bars?
Frodoe is offline
post #5 of 60 (permalink) Old 08-11-2010, 10:40 PM Thread Starter
gabbyduffy's Avatar
these bars are called +2, there made by cycle vision. there the same style as stock only 2 inches taller, u can find them in drags fat book.
post #6 of 60 (permalink) Old 08-12-2010, 09:06 AM
xusnatc's Avatar
I'm thinking that if you use your stock bars and either a 4 or 6 " riser it will do just fine.
xusnatc is offline
post #7 of 60 (permalink) Old 08-12-2010, 09:56 AM
This is exactly what I was thinking of doing. Maybe a dumb question, but will any riser for a harley work on an RG?
TobyJ is offline
post #8 of 60 (permalink) Old 08-12-2010, 01:35 PM Thread Starter
gabbyduffy's Avatar
RG with risers.
yes, risers will work just fine with your stock bars. your stock bars look really good on roadglides, there just a little to low for my taste. I have a bad back and i've found out when I raise my bars to be in line with my shoulders it takes the pressure off my lower back. its real hard to find a set of bars that look good on a roadglide. When you go with the risers its nice because you can keep all the wires outside the bars. With the new fly by wire system it's a pain to get all the wires inside the bars. When you leave the wires outside the bars you have options, you can change the bars easily, you can change the risers, you can add riser extentions, if theres a short in a wire its easy to access.
post #9 of 60 (permalink) Old 08-12-2010, 01:37 PM Thread Starter
gabbyduffy's Avatar
risers
yes, you can use any risers, I think chubby, burly bars, makes the nicest stuff.
post #10 of 60 (permalink) Old 08-12-2010, 02:57 PM
nice alternative, thanks for the pics!
2010 FLTRX VB
Autobred is offline
check out these guys mslater7412 Videos 2 08-14-2013 08:24 PM
Check Out These Custom New Boards Louster47 *General Road Glide Discussions/Pictures 20 08-07-2013 01:35 PM
Guys check these out!!! lundboy1 Controls & Handlebars 3 02-06-2013 09:25 AM
Check out these little lights DED HD Lighting 4 04-02-2012 01:56 PM
Check out these Hot Legs / forks. And some powder coating clloyd *General Road Glide Discussions/Pictures 19 01-19-2012 12:33 PM
