removing grips - Road Glide Forums
post #1 of 11 (permalink) Old 06-30-2012, 03:42 PM Thread Starter
removing grips
any ideas on how to remove glued on Iso Grips? Had the clutch loose because of the bar swap that is about to happen and took bike to shop for service....i'll be damned if the mechanic didnt glue them on tight.
2012 HD Road Glide Ultra
Willie G chrome accessories
RineHart exhaust
LA Choppers 18" apes
progressive front lowering springs
6" FBI windscreen----freaking useless
Scrape Made MagLite mount for apes
on the wish list:
Cyclent Cycles stretched bags and rear fender
painted inner fairing
Gabriel rear air shock with compressor
21" front
powdercoating:
most engine chrome and accessories
tour pack docking
LARGECARTRANSPORT is offline
post #2 of 11 (permalink) Old 06-30-2012, 03:55 PM
Take off the switch housing and the clutch bracket and let the sun heat up the grip for a while if you have a heat gun it would help, then twist and pull. I am just grabbing at straws here but heat usually softens glue. There is absolutely no reason to glue the grips on these bikes so I would stay far away from the Tech that did it. If you can't get it off you can take off the end cap and try to get a screw driver between the grip and the bar to break it loose.
post #3 of 11 (permalink) Old 06-30-2012, 04:12 PM
Harleyagain's Avatar
Depending on the grip, you can used compressed air to break the glue seal.
Bob
Harleyagain is offline
post #4 of 11 (permalink) Old 06-30-2012, 05:37 PM Thread Starter
great info...i will try both ways if needed. thanks for the quick help. thanks again
RineHart exhaust
on the wish list:
21" front
powdercoating:
tour pack docking
post #5 of 11 (permalink) Old 06-30-2012, 08:09 PM
FrankieB's Avatar
Cut it off and pick up another set of iso's. To much trouble to try and pry them off just to have a stretched grip or broken chrome.
06 RK
11 RGU
FrankieB is offline
post #6 of 11 (permalink) Old 06-30-2012, 08:40 PM
Per the Iso Grip instructions it says to glue the clutch side grip on. They even come with the glue to do it. That sucker is bonded on there, so it isn't coming off in one piece. Time for new grips!
If what you're doing ain't working.......TRY SOMETHING DIFFERENT!
tyrtek is offline
post #7 of 11 (permalink) Old 06-30-2012, 08:54 PM
Try twisting?
When I did the bar swap on my 11 RGU I was able to grab the grip and twist it off. I'm not saying it broke free immediately or without some effort, but it let loose. If it won't free up, I think Ironmark had a good idea with the heat---probably would be worth a try.
Craig
craigp95 is offline
post #8 of 11 (permalink) Old 06-30-2012, 09:14 PM
Ranger75's Avatar
I used compressed air and some prying between grip & bar to remove my stockers when I changed bars. Have to disagree in no need for glue, yes the new grip will not come off with the clutch perch / controls holding it on, but it will rotate easily if not glued. Not a huge problem but I prefer mine to be on there solid...
Be polite, be professional, but have a plan to kill everyone you meet.
Ranger75 is offline
post #9 of 11 (permalink) Old 06-30-2012, 10:27 PM
MyloFiore's Avatar
+1 on clutch side glue. I don't think a heat gun would work. The glue that comes with the grips is the cyroacrylate (super glue) variety. Some nail polish remover or acetone might loosen it up.
2011 FLTRX Road Glide Custom
2002 FXSTDI Softail Deuce (sold)
MyloFiore is offline
post #10 of 11 (permalink) Old 07-01-2012, 09:09 AM
HD grips do not require any glue on either side and they don't rotate except for the throttle side when I twist the wrist.
Sharknose < Batwing = ease of removing CHAINSAW *General Road Glide Discussions/Pictures 51 10-08-2018 02:12 PM
Removing and reinstall heated grips Old bear Controls & Handlebars 3 09-01-2018 10:48 AM
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 07:01 PM
removing cats from cvo bikes digga25 Intake and Exhaust 7 09-22-2010 11:02 AM
Removing V & H Baffels blacktopr Intake and Exhaust 8 03-22-2010 07:07 AM
