Help with installing new Clutch Cable - Road Glide Forums
post #1 of 6 (permalink) Old 07-02-2012, 01:05 PM Thread Starter
carcass's Avatar
Hi all,
Going to swap out my clutch cable and wondering if there are any tips/tricks/incantations out there before I start?? Looks pretty straight forward from the lever down to the case, but what (if any) issues are there with opening the case and hooking it up? Any diagrams to look at?
TIA,
Carcass
2012 Black RG FLTRX
103" Stage II 255 Cams
Heavy Breather Intake
Fuel Moto 2-1-2 Headpipe
4" Dyno Tuned Mufflers
Power Vision
-- "Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
carcass is offline
post #2 of 6 (permalink) Old 07-02-2012, 02:22 PM
faststan's Avatar
Very straight forward. You may have to remove the exhaust to get to all of the bolts in the clutch cover.
When you run the cable be sure to retrace the original placement before installing in housing. Have a grease pan under clutch cover as you may lose a little oil from trans.
Remove the clutch cover,
remove the 'C' clip,
remove the cable from lever and install new cable into clutch cover.
(There is a rubber o-ring on the cable going into the housing. Make sure it is snug but not too tight as it will distort or break the o-ring. New cable should come with a new rubber o-ring.)
install new cable into lever,
make sure the 3 pivot balls are in their respective indentations,
install the 'C' clip and reinstall the clutch cover.
If cover gasket is broken or twisted, replace it.
Check the fluid level in the trans and fill as needed. A little low is ok.
Make sure the 'C' clip is in the same location as when you take it apart. The manual is adamant about this placement. Use of a pair of needle nosed pliers will work to remove/replace 'C' clip if you don't have a correct 'C' clip remover plier.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 6 (permalink) Old 07-02-2012, 02:32 PM Thread Starter
carcass's Avatar
What are the three pivot balls? Are they messed up easily??
2012 Black RG FLTRX
Power Vision
Ronald Reagan
carcass is offline
post #4 of 6 (permalink) Old 07-02-2012, 05:55 PM
faststan's Avatar
The reside under the clutch lever plate. They are what makes it easy to pull the lever in. They are sitting in reliefs in the housing. The plate sits on top of those balls and kind of 'rolls' rather than add friction to the pull. I think it is called a 'ball ramp'.
http://partsfinder.onlinemicrofiche....W/-SIDE-COVERS
faststan is offline
post #5 of 6 (permalink) Old 07-03-2012, 12:24 AM
MassHD's Avatar
Also ride up on a 2 by 4 so the bike will lean over when you put down the kick stand. That way you won't lose any oil when you pop off the cover.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #6 of 6 (permalink) Old 07-03-2012, 12:27 AM Thread Starter
carcass's Avatar
Ok, thanks all!
2012 Black RG FLTRX
Power Vision
Ronald Reagan
carcass is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Clutch cable routing help hotrodad Controls & Handlebars 14 07-12-2013 05:26 AM
Installing Longer Clutch Cable on Stock Bars? kevanbo Controls & Handlebars 9 06-20-2013 09:10 AM
Clutch cable problem after installing new bars WIKD1 Controls & Handlebars 16 12-11-2012 03:37 PM
