need help - Road Glide Forums
post #1 of 8 (permalink) Old 07-08-2012, 05:12 PM Thread Starter
need help
Guys, hope you can help .... just did the internal wiring for my new bars....
here are my issues :
horn doesn't work
non of the blinkers or brake lights work
and i keep popping an accessory fuse.... ????
anyone have a wiring diagram for the white connector ? i wrote it down but now im guessing i wrote something wrong...
12 RoadGlide Custom
Rinehart 2 into 1
PC V
RSD Black OPS A/C
12" HD WindSplitter
pwalsh1019 is offline
post #2 of 8 (permalink) Old 07-08-2012, 05:47 PM
Classic symptoms of at least one pinched wire, especially the ACC fuse that keeps blowing. Take the switch housings apart and look for flattened/bare spots on the wires that result from being pinched between the clamp and the bar. Pay extra close attention to where the wires enter and exit the bar.
SickRick is offline
post #3 of 8 (permalink) Old 07-08-2012, 06:08 PM
Shrug's Avatar
Send a message via Yahoo to Shrug
I have a 2010 RG Custom service manual. Wiring for a 12 might be different, but if you don't get any help here and want me to, I'll try to scan the wiring diagram for you.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #4 of 8 (permalink) Old 07-08-2012, 07:01 PM Thread Starter
that would be great my email is [email protected]
just wanna make sure i have that part right...
12 RoadGlide Custom
Rinehart 2 into 1
PC V
RSD Black OPS A/C
12" HD WindSplitter
post #5 of 8 (permalink) Old 07-08-2012, 08:03 PM Thread Starter
also do you guys know which wires control the blinkers and horns? and why would the brake lights stop working?
12 RoadGlide Custom
Rinehart 2 into 1
PC V
RSD Black OPS A/C
12" HD WindSplitter
post #6 of 8 (permalink) Old 07-08-2012, 09:29 PM
L-Premo's Avatar
Per the '11 manual fig. B20, Right Signal O/W (Position 1 on plug) & W/BN (5)
on the Left Signal O/W (1) & W/V (5), Horm O/W (1) & Y/BK (6)
Second the check for a crimped wire at the switch housing. Kept blowing headlight fuses found a crimped wire on the left side.
One final suggestion, purchase a manual. Best $60 I've spent so far.
I ride a Road Glide. Therefore I am!
'11 RGU Merlot Sunglo, Daymakers, Rinehart slip ons, stage 1, throttle pak, tour pak relocator, Madstad, Black +2 Sweepers, black ISO grips, split view mirrors, Transformer floorboards.
L-Premo is offline
post #7 of 8 (permalink) Old 07-09-2012, 11:04 AM
Roadie09's Avatar
Will the brake light come on if you use the rear pedal?
The brake switch for the front brake lever is easy to damage during installation of the grips/housings. That will not take care of your other issues, but may explain the brake light not working.
The other issues are either crossed wires in the plugs (double check to make sure they are back in the same location they came from) or pinched/shorted wires.
I have done the wiring in a poorly lit garage before and it is easy to cross some of the darker colored wires (at least for my old eyes).
Roadie09 is offline
post #8 of 8 (permalink) Old 07-09-2012, 02:13 PM Thread Starter
guys wanted to thank so much for pointing me in the right direction ... i thought my issue was on the left side but it seems the short is coming from the right side , since if i unplug the right (Black) side my fuse doesnt pop .... if plug the black back in and un do the left side the fuse pops.... started tracing the wires now will keep ya posted...
12 RoadGlide Custom
Rinehart 2 into 1
PC V
RSD Black OPS A/C
12" HD WindSplitter
Need help - need a tuner with some skills in SW Mich Captain America Dyno Results 1 06-02-2017 11:51 PM
need help figuring which bars I need ironmike666 Controls & Handlebars 14 01-06-2013 10:56 PM
Need help setting up my wife's Road Glide NCTim *General Road Glide Discussions/Pictures 5 11-09-2010 11:27 AM
Need help on winshield size RWB427 *General Road Glide Discussions/Pictures 12 06-28-2010 12:10 PM
Need your help HUTMO Windshields 9 03-20-2010 08:00 PM
