Front brake line replacement help - Road Glide Forums
post #1 of 4 (permalink) Old 07-11-2012, 12:32 PM Thread Starter
My indy ordered Drag specialties 1741-2512 for my 12 road glide custom. Should I have to modify the mounting block that the bolt runs through to accomodate the alignment pin that is mounted on the bike next to the hole?? It will not sit flush unless I grind a small indention into the block for the pin to sit in. any help appreciated
MoRob is offline
post #2 of 4 (permalink) Old 04-03-2013, 10:17 PM
DewmanCO's Avatar
Any word on this? I'm in the same situation. The Drag Specialties lines don't accommodate this pin on the 2013s. Can we just grind it off?
Mathematics - as relentless as the laws of gravity - is nonnegotiable
DewmanCO is offline
post #3 of 4 (permalink) Old 04-03-2013, 11:16 PM
DewmanCO's Avatar
Did a little searching and it sounds like you can either pull the pin that is supposed to keep the factory brake mount from moving or grind it off if it doesn't come out.
Just in case anyone else is looking...
https://www.roadglide.org/showthread.php?t=30083
DewmanCO is offline
post #4 of 4 (permalink) Old 04-04-2013, 10:13 PM
NWA_RoadGlide's Avatar
Pull it out.
I used a pair of vise grips twisting and pulling until it popped out. It's just a roll pin.
2012 Road Glide Custom / Big Blue Pearl
NWA_RoadGlide is offline
brake line replacement dochawken Tech Area 3 05-15-2014 01:53 PM
Front Brake Line Replacement Question Trip20 *General Road Glide Discussions/Pictures 4 07-22-2013 12:14 PM
LA Choppers extended front brake line help. mandlbarrett Controls & Handlebars 7 07-22-2012 08:52 PM
Replacing stock front upper brake line SickRick Controls & Handlebars 2 09-02-2011 06:24 PM
Stock 1 piece front brake line Too Short Classifieds Archive (3 months old+) 0 08-01-2011 09:30 AM
