Heat shrink size? - Road Glide Forums
post #1 of 4 (permalink) Old 07-12-2012, 12:33 PM Thread Starter
MarkR's Avatar
Heat shrink size?
I'm finally going to have time to install my WO612 CHUBBY® 12" OUTLAWZ. My question is what diameter and length of heat shrink do I need?
2012 road Glide ultra rinehart 2 to 1, SERT, K&N intake, mustang seat, Heritage bars, etc...
Sold 2007 ultra classic rinehart true duals, SERT, etc...
Sold 1999 Heritage, true duals, etc...
MarkR is offline
post #2 of 4 (permalink) Old 07-12-2012, 02:17 PM
faststan's Avatar
When I installed mine I bought 2 36" x 1/2 tubes. I probably had 8 - 12 inches left when I got the part covered that I wanted. Better too much than not enough. Keeps you from stripping the cover off a wire when feeding it thru the bars. Good luck.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 4 (permalink) Old 07-13-2012, 03:04 AM
PFWiz's Avatar
I only used heat shrink for making the pecker heads to pull the cable bundles. I stripped the sections of cable that came out the bottom of the bars to make them smaller / more easily pulled. I ty wrapped on a split covering to everything that came out the bottom.
PFWiz is offline
post #4 of 4 (permalink) Old 07-13-2012, 03:34 AM
Heat shrink
Do yourself a favor a get rid of the stock throttle sensor,the screaming eagle is one piece comes with everything you need. That green plug will give you fits at times.this is from experiance,had mine apart 3 times before I got it right. Just a little tip use wire pulling soap and make sure your holes where the wire goes in and comes out is filed so there is no sharp edges to nick the wire
Jerry W. is offline
Harley Davidson Cover, DEFIANCE Foot Pegs, Shrink Sacks merritta Parts for Sale 3 04-06-2018 09:36 AM
Shrink Sacks JacktheBagger *General Road Glide Discussions/Pictures 13 06-04-2017 08:14 PM
Temp gauge bulb size? raven006 Troubleshooting for Road Glides 31 03-27-2014 03:46 AM
Shrink Sacks dinggus Aftermarket Accessories 22 12-07-2013 09:35 AM
Dragos vs Stock Heat Shield Size SIG556 Intake and Exhaust 5 08-11-2012 05:08 PM
