big time ape hanger install problem - Road Glide Forums
post #1 of 4 (permalink) Old 07-12-2012, 08:42 PM Thread Starter
I got the 18" apes wired and plugged back in....no problem. I then went to test start in neutral without levers hooked up yet....and POW...nothing. Oops, told myself not to forget the tach/speedo/headlight plugs. Well, now that is plugged in...ignition, start....WHOA...little delayed crank and then wide open throttle. Shut down. Try again...wide open throttle. What am I missing here? Also, from what I can tell...all switches are working except for volume for speakers. Thanks in advance for the help. PS...baby powder is freaking great...coated cables and inside bars then slid right in...no problem
2012 HD Road Glide Ultra
Willie G chrome accessories
RineHart exhaust
LA Choppers 18" apes
progressive front lowering springs
6" FBI windscreen----freaking useless
Scrape Made MagLite mount for apes
on the wish list:
Cyclent Cycles stretched bags and rear fender
painted inner fairing
Gabriel rear air shock with compressor
21" front
powdercoating:
most engine chrome and accessories
tour pack docking
LARGECARTRANSPORT is offline
post #2 of 4 (permalink) Old 07-13-2012, 03:56 AM
FrankieB's Avatar
Check your DBW connector if you pulled it apart. You may have gotten the wires backwards.
06 RK
11 RGU
FrankieB is offline
post #3 of 4 (permalink) Old 07-13-2012, 06:53 AM
FrankieB is right on the money, sounds very much like wires are backwards... also after you get that sorted make sure you clear you codes sometimes changing the ignition can throw codes and put the bike in "limp" mode.... i just spent 3 days troubleshooting putting my new bars on ...
12 RoadGlide Custom
Rinehart 2 into 1
PC V
RSD Black OPS A/C
12" HD WindSplitter
pwalsh1019 is offline
post #4 of 4 (permalink) Old 07-13-2012, 07:01 PM Thread Starter
thanks guys for the answers...yep yall were right on the money. flip them around and repulled cable..voila...good throttle . thanks again Shannon
RineHart exhaust
on the wish list:
21" front
powdercoating:
tour pack docking
Ape hanger width question Midnightchoppers Controls & Handlebars 0 01-01-2013 04:18 PM
ape hanger help suicidecj5 Controls & Handlebars 17 07-12-2012 07:33 PM
Ape hanger question Dirty Irish Controls & Handlebars 10 06-05-2012 10:54 PM
