Help with re installing wires in plugs - Road Glide Forums
post #1 of 7 (permalink) Old 07-19-2012, 01:58 PM Thread Starter
MarkR's Avatar
I've ben trying to connect the wires back to the plugs after my wire pull for a few hours. I can't get the internal white piece to push back down far enough to connected to the other plug. I have pulled the wires to make sure the flat side is facing inwards. Any tips?
2012 road Glide ultra rinehart 2 to 1, SERT, K&N intake, mustang seat, Heritage bars, etc...
Sold 2007 ultra classic rinehart true duals, SERT, etc...
Sold 1999 Heritage, true duals, etc...
MarkR is offline
post #2 of 7 (permalink) Old 07-19-2012, 02:12 PM
I ran into the same problem with the molex plug part. I pushed and pushed and couldnt get the white part to seat correctly. It only happened on the clutch side though....so after a little frustration I called upon my neighbor(who I found out recently is a HD mechanic at my dealer) and he proceeded to take needle nose pliers and seated the white piece until the the pins were sticking thru....then he took a rubber mallet and tapped the pliers and voila...seated.
2012 HD Road Glide Ultra
Willie G chrome accessories
RineHart exhaust
LA Choppers 18" apes
progressive front lowering springs
6" FBI windscreen----freaking useless
Scrape Made MagLite mount for apes
on the wish list:
Cyclent Cycles stretched bags and rear fender
painted inner fairing
Gabriel rear air shock with compressor
21" front
powdercoating:
most engine chrome and accessories
tour pack docking
LARGECARTRANSPORT is offline
post #3 of 7 (permalink) Old 07-19-2012, 02:59 PM Thread Starter
MarkR's Avatar
Ok I figured it out. Once you have all the pins inserted and the white piece in the unlock position. you need to pull the wires outward to lock the pins in place. Once I did that the white piece went right in to the lock position.
And as I bonus to me i fired the bike up and everything seems to work as it should. Now to put the the faring back on and go for a few rides to get the bars adjusted.
MarkR is offline
post #4 of 7 (permalink) Old 07-19-2012, 05:02 PM
good to know u got it fired...iwhen I first did it I got the tbw sensor backwards...as soon as it fired it was uncontrolled throttle(lol)...had to take out and flip the wires....live and learn
RineHart exhaust
on the wish list:
21" front
powdercoating:
tour pack docking
post #5 of 7 (permalink) Old 09-21-2012, 10:52 PM
Can someone tell me how far the ETC is supposed to slide into the notches of the bars? I am reinstalling mine on new bars and it barely slides into the notches before it stops. Thanks
Roadglide_Rider is offline
post #6 of 7 (permalink) Old 09-22-2012, 07:11 AM
faststan's Avatar
You probably have debris or rust inside the bar. Use a rag on the end of a screwdriver and push into bar end. Try this several times. If that doesn't finish the job, use a rat tailed file to smooth out the edges of the indentation. Good luck.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 7 (permalink) Old 09-23-2012, 07:31 AM
Thanks. I think the new bars didn't account for the chrome coating. Got everything worked out.
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
Re-pinning the Throttle Control Actuator Plug Wires ironmark Troubleshooting for Road Glides 2 04-14-2015 07:39 PM
help identify plugs biackbenz Do-IT-Yourself 2 05-15-2014 06:56 AM
Installing New Spark Plug Wires Captain13 Equipment-RG 16 08-23-2013 07:49 PM
Exhaust Leak- Re-installing Exhaust System tonight X In Black Intake and Exhaust 13 02-27-2013 03:21 PM
