Expected life of clutch cable - Road Glide Forums
post #1 of 6 (permalink) Old 07-23-2012, 08:25 AM Thread Starter
Roadie09's Avatar
I did not want to hijack the SWII damage report, but I have noticed several reports of failed clutch cables.
Anybody have an idea what the average usable life of the cable is? I know every situation is different, but surely they don't last forever. I am wondering if I should replace the cable while the bike is in my garage before the next long trip. It does not appear to be something I want to do in a parking lot in the middle of nowhere.
Roadie09 is offline
post #2 of 6 (permalink) Old 07-23-2012, 08:28 AM
tdkkart's Avatar
I traded my '01 Ultra last summer with just short of 40,000 miles, still had the original cable. Keep it lubed and properly routed and you it should last a LONG time.
You'll notice that HG WLD said that his cable may have been getting pinched by the fork triple tree because of the way it was routed.
tdkkart is offline
post #3 of 6 (permalink) Old 07-23-2012, 09:04 AM
EdY39's Avatar
I ran a 1999 EG 133,000+ miles with the same clutch cable. Not a problem at all. Keep it lubed and, as mentioned, make sure it's not binding anywhere. I've got a buddy in Miami with over 200,000 miles on a 1996 EG with the same clutch cable on it. Any bike I look at, I always check to make sure the cable isn't also rubbing on anything down by the lower right side frame rail. Looks for wiring rubs, brake line rubs, etc.
Ed
2002 RoadGlide
DPCM, USN (Retired)
EdY39 is offline
post #4 of 6 (permalink) Old 07-23-2012, 09:16 AM
As long as the clutch cable doesn't have a sharp bend in it everything should be good. The new clutch cables have a plastic coating on the cable itself and this aids in the smooth function of the cable. I have a different point of view on lubricating the clutch cable the way I see it the lubricant becomes a dirt trap and the dirt will build up and eventully cause cable failure. I have over 50,000 miles on my bike and I never used any kind of lubricant on the clutch cable and the clutch cable functions just like it did when I rolled the bike off the showroom floor.
post #5 of 6 (permalink) Old 07-23-2012, 10:45 AM
Redfish-Joe's Avatar
60k on my 2000 RK
50k on my 2008 RG
40k on my 2011 RG
No clutch cable failure. I did have the one replaced on the 08 because it was started leaking oil from the tranny.
Redfish-Joe is offline
post #6 of 6 (permalink) Old 07-23-2012, 10:54 AM
Originally Posted by Redfish-Joe View Post
60k on my 2000 RK
50k on my 2008 RG
40k on my 2011 RG
Was it the cable itself that caused the leak or did the o-ring on the cable where the cable enters the trans go bad? The o-ring is repairable.
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Expected Results CSM11 Engine Related 2 04-10-2012 02:03 PM
Don't ya' just love it when something cool just happens? Unplanned, or expected? BaggerFLTR *General Road Glide Discussions/Pictures 31 09-05-2011 10:55 PM
