"frayed" wire - Road Glide Forums
post #1 of 4 (permalink) Old 08-22-2012, 10:37 PM Thread Starter
Robare's Avatar
"frayed" wire
I'm in the proess of putting on some bars, and I'm re-wrapping the wires with some heat shrink tube covers. Anyway a few months back I had some issues wiith my radio controls and it was becaus of pinched wires. I loosened the control brackets and found a wire or two out of place. put back together and everything worked fine.
So this is what I have now. A couple of wires are frayed and/or crushed. I think I'd be ok with just wrapping some with electrical tape and then shrinking the cover tube over them. Sound about right? or is there a better way to handle them so I don't have issues donw the "road".
Robert, Robare, Row-b-bear
'07 HD Roadglide (2/2/12 - Current)
'01 ZRX1200R (8/29/06 - 4/30/12)
'91 VFR 750 ('04)
'87 FZ 600 ('03)
'86 YZ125 (86-89)
70's Honda Trail 70 (82-89)
Robare is offline
post #2 of 4 (permalink) Old 08-22-2012, 11:47 PM
JJSW1283's Avatar
I would cut that bad spot out, solder it and heat shrink.
JJSW1283 is offline
post #3 of 4 (permalink) Old 08-23-2012, 03:06 AM
+1, and if the wire is short, put a small splicing in. With the vibration in the bike and the pinch in the wires, its likely to cause intermittent problems down the road.
post #4 of 4 (permalink) Old 08-23-2012, 03:52 AM
Bigtrev8xl's Avatar
Just slip some heat shrink over it that would be fine.
I DON'T DO RUSHING!
Bigtrev8xl is offline
14" buky malo wire extensions?? bigpimpn916 Controls & Handlebars 1 02-18-2014 04:12 PM
"Meat hook" type bars-Horrible to wire??? Halstem1 Controls & Handlebars 12 08-08-2013 10:53 PM
I noticed a Drive by Wire "Wierdity" tdkkart *General Road Glide Discussions/Pictures 2 07-04-2011 08:58 AM
How to internally wire handlebars (especially bars with sharp bends) The Infamous Sharknose Controls & Handlebars 8 12-16-2010 11:25 AM
