Detailed Reroute - Road Glide Forums
post #1 of 17 (permalink) Old 08-30-2012, 08:50 PM Thread Starter
Nchoman's Avatar
Detailed Reroute
Ok, purchased some chubby W0502's and with everything I have read on here I was hoping that the stock cables would make it. Seems I was wrong. Probably due to the slightly wider grip on them.
Anyway, if anyone can show me a way to reroute the stock cables to make them reach I would greatly appreciate it. Did some searching around and while I have seen some configurations, they have been on skinnier setups. If I cant find a way to reroute them I will just grab some +4's and be done with it.
Such is the life of a self modder eh.
12' BBP RGUltra, dual dragulas, tman tq555's, tmax, zippers air, daymakers, 12.5 apes, odds and ends
Nchoman is offline
post #2 of 17 (permalink) Old 08-30-2012, 09:47 PM
faststan's Avatar
i tried the normal reroute and didn't like it. I bought +4 and ran in the stock place. I only paid 59.00 for the clutch cable at local indy and installed it myself. Perfect fit. I released the cable tie inside the guage nacelle for the brake line and moved the upper cable outside of it. (I have ABS). This is my install and others may have different results......
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 17 (permalink) Old 08-31-2012, 02:47 PM Thread Starter
Nchoman's Avatar
Thanks for the response faststan.
I went ahead and ordered both lines today. Tried every configuration I could think of and all of them fell just short of the mark. Even if I could have somehow gotten them on, there wouldn't have been enough slack leftover. Well, I will pull the tank this weekend using a DIY post I saw today and get everything prepped up for the swap Tuesday night.
So word to those that are looking at the Wild1's 12.5" Chubby bars #W0502, the stock clutch and brake lines were too short. Going with +4's to give it plenty of slack. 67" for both I think is what I ordered.
Nchoman is offline
post #4 of 17 (permalink) Old 08-31-2012, 02:54 PM
spokanebagfan's Avatar
Nchoman where did you get your cables from at thay price?
spokanebagfan is offline
post #5 of 17 (permalink) Old 08-31-2012, 03:54 PM Thread Starter
Nchoman's Avatar
I ordered from a local indy close to my work. I think the clutch is $50 and the brake line is about $39. They are just a black vinyl coated line. Nothing special, just black. I will need to pick up the fittings as well and those run about $10 apiece. Priced out of Fatbook.
Nchoman is offline
post #6 of 17 (permalink) Old 08-31-2012, 06:06 PM
CHAINSAW's Avatar
There is a way,.. but my memory is working right now. Im running 15" apes with all stock cables and lines, just rerouted.
Such is the rule of honor.
CHAINSAW is offline
post #7 of 17 (permalink) Old 08-31-2012, 06:08 PM Thread Starter
Nchoman's Avatar
Well hop on that black beast of yours and cruise on over to Wichita and show me.
Nchoman is offline
post #8 of 17 (permalink) Old 08-31-2012, 06:31 PM
BCRG's Avatar
If
Hey Chain, If ya can remember that'd be cool. I'm mod cash poor right now,
but was mulling the WO515's or the WO612's. I had WO502's on my road king and they were great. If there's enough wiring tucked inside the fairing and a re-route of the clutch/brake is doable, then I'd go back to the 502's.
BCRG is offline
post #9 of 17 (permalink) Old 08-31-2012, 06:51 PM Thread Starter
Nchoman's Avatar
I've got wiring to spare on the 502's, just working the cables. I had the 14" chubbs on my 05King and loved em. Thats what helped with my decision to go with the 12.5's. I'm going to go out there and mess around a little more with the cables but not going to stress over it.
Nchoman is offline
post #10 of 17 (permalink) Old 08-31-2012, 10:34 PM
CHAINSAW's Avatar
Wildones are just so damn wide, your probably right in not having enough length. My bars are only like 34" grip to grip.
I can remember I took my tank off and pulled the ABS line till it had no more slack. I also rerouted it to come up between the tank and the triple trees,.. I think stock it goes through triples and in front of the top tree.
The clutch I cut a couple zip ties on the bottom frame rail, and routed it between the exhaust pipe and frame. Then I zip tied it against the frame so it wouldnt slack back and hit the pipe. Has held up fine for 18K miles or so. It also comes up between the tank and the triple trees. Clutch I might of had another 1", but ABS line is tight at full left turn, no extra.
CHAINSAW is offline
Le Pera Maverick seat review - long & detailed! Methos1979 Seating: seats, backrests 105 07-27-2019 01:19 AM
ASTech seat mod on my LePera Maverick - detailed review Methos1979 Seating: seats, backrests 12 06-19-2016 10:23 AM
Review: Scorpion EXO-CT220 3/4 helmet (long, detailed) Methos1979 Helmets 3 05-12-2015 08:00 PM
Clutch cable reroute following 12" install 407Driver Controls & Handlebars 6 09-11-2014 10:07 AM
Detailed TBW Thread billd76 Troubleshooting for Road Glides 0 09-25-2013 07:29 AM
