Wiring and Switches for Yaffe Handle Bars - Road Glide Forums
post #1 of 9 (permalink) Old 09-06-2012, 10:09 PM Thread Starter
Pistokcha's Avatar
one more try.......I have some 10" Yaffee's that I plan to install soon. I want to pre wire before I pull off the stock bars, so I don't plan to reuse my wiring. I hope this shortens the amount of down time while swapping bars. So, I need a wiring set up for the Yaffee's. Anyone that went taller than 10" and had to buy a new longer wiring set up, want to sell their old wiring harness and switches?? Let me know.....................
2011 FLTRX Sedona Orange
Pistokcha is offline
post #2 of 9 (permalink) Old 09-07-2012, 07:44 PM Thread Starter
Pistokcha's Avatar
Yaffe Bars and Wiring
Did I post this too late last night? No views even..............come on, someone help me out...................
post #3 of 9 (permalink) Old 09-07-2012, 08:07 PM
cypress's Avatar
Sounds like a good plan if you can get the wiring. I'm curious to know how much a second set of wiring costs since this project has some risk of wiring damage and I'm thinking of doing it myself.
2012 FLTRU - Custom Candy Orange - Dynojet PowerVision - V&H Monster Rounds - FuelMoto Pro Billet A/C
cypress is offline
post #4 of 9 (permalink) Old 09-08-2012, 07:40 AM
Grapnel's Avatar
I just installed my 12in monkey bars and used the factory wiring. my understanding is that you actually only buy wire extensions, not a new wire harness.
Grapnel is offline
post #5 of 9 (permalink) Old 09-08-2012, 07:59 AM
HD_Shock's Avatar
I've seen used control wiring sets for sale occasionally but not very often. You have a good plan if you can find them. I wouldn't sweat it too much though if you can't. Just dive in, eliminate the green TBW plug by hard wiring (or move to the fairing like I did), and get it done.
Maybe for practice, bundle up a set of generic wires and run them through. That way you can get a feel for the trouble spots before you use your control wiring.
-phil
2011 FLTRX 103
HD_Shock is offline
post #6 of 9 (permalink) Old 09-08-2012, 08:11 AM
elric_w_wolf's Avatar
I can tell you from my experience with 10" Monkey Bars Thursday and Friday that there is plenty of wire with the stock harnesses - they will not hang back on the side of the radio like they were stock but they are plenty long enough - the only one that might be too short for your liking is the TBW harness - this harness I had to relocate the plug (the one under the fairing) between the gauges and the inner primary. There is also plenty of clutch and brake cable.
This project was a real b&t%h! I don't see how some people were able to leave the green TBW plug on - I had to cut it off and solder the wires together in order to get everything in the throttle side.
They look great but man on man what an ordeal.
2012 FLTRX 103 Denim Black
elric_w_wolf is offline
post #7 of 9 (permalink) Old 09-08-2012, 08:16 AM
Wiring
Save yourself a headache and get the screaming eagle throttle sensor,and strip the bulky black harness sheath,and put on heat shink tubing and shrink it, much easier
Jerry W. is offline
post #8 of 9 (permalink) Old 09-08-2012, 08:19 AM
I almost did that and if I had it to do over - I would definitely go that route.
You got a second on this from me!!
post #9 of 9 (permalink) Old 09-08-2012, 09:29 AM
DonJulio's Avatar
Agreed, I heat shrinked the whole thing. That stuff is tougher and can handle the snaking process. I still had to basically cut the harness and stagger the solder connections to prevent it from becoming too bulky. didn't have to extend them at all.
Sent from my MyPhone
2011 RGC
23" Pickard Heavy Hitter Front w/matching rear , Homemade Air Ride, Pickard Raked Trees, Pickard 23" Smooth Fender, Vivid Black painted Inner, 10" Yaffe OEM Monkey Bars, Ness RAD III Controls, Ness Grips, Ness Mirrors, 4"Rineharts, PCV, ThrottlePak, HD Heavy Breather, American Suspension Fork Bomber Fork Lowers, Klockwerx 8" black windshield, Sinister Pissed off Headlight Bezel, HID Headlights Custom Dynamics LEDs
DonJulio is offline
Wiring Clarion to handlebar switches mouser58 Audio 3 07-09-2015 12:13 PM
Yaffe Monkey Bars Install wiring tip cmacclel Controls & Handlebars 22 05-12-2015 03:08 PM
changing handle bars to electra glide std bars sheriff61 Controls & Handlebars 7 08-27-2014 09:35 PM
stock switches, wiring & stock switch covers Pistokcha Controls & Handlebars 0 08-25-2012 07:35 PM
Ok.. Now I am stuck (Handle Bar internal wiring) habu_sake Controls & Handlebars 16 01-11-2011 08:36 AM
