Switched grips, now cruise only works sometimes - Road Glide Forums
post #1 of 19 (permalink) Old 09-09-2012, 07:49 PM Thread Starter
TRUBlue's Avatar
I had a bad HD grip and was given a new one under warranty. After installing the new grip, the cruise control will only engage sometimes. I'm assuming a pinched wire although I'm sure there could be other causes.
Anyone else have a similar problem? What's the fix if it is pinched wire?
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #2 of 19 (permalink) Old 09-09-2012, 08:28 PM
Triplej's Avatar
Like you said there is a good chance it is a pinched wire. I would recommend repairing the pinched wire by having the wire soldered and cover the repaired section with heat shrink tubing. Not hard to do if you have the tools but may be worthwhile to let some one else do it if you don't already have them for just one wire.
Triplej is offline
post #3 of 19 (permalink) Old 09-09-2012, 09:07 PM
I would look into the front brake light switch. If you did not follow the correct procedures when working on the switch housings you could damage or dislocate the brake light switch. If the brake light turns on even for a split second the cruise will disable and if the brake light is stuck on the cruise will not set. Check to see if the brake light is stuck on or have someone follow you and see if the brake light is flashing on/off.
post #4 of 19 (permalink) Old 09-09-2012, 10:26 PM Thread Starter
TRUBlue's Avatar
I had the manual out doing the switch and tried to follow the instructions to a T, still a chance you're right though. Have to check it out tomorrow. Thanks for the info.
TRUBlue is offline
post #5 of 19 (permalink) Old 09-10-2012, 08:36 AM Thread Starter
TRUBlue's Avatar
I would look into the front brake light switch. If you did not follow the correct procedures when working on the switch housings you could damage or dislocate the brake light switch.... Check to see if the brake light is stuck on or have someone follow you and see if the brake light is flashing on/off.
Yep, brake light on constant. I guess I have to take it back apart and see what happened. Any pointers so I don't have to keep doing so?
TRUBlue is offline
post #6 of 19 (permalink) Old 09-10-2012, 08:56 AM
faststan's Avatar
I cut off the tip of a plastic tie and used it as an insert to keep the lever off the switch. Anything will work as long as it doesn't slip out.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 19 (permalink) Old 09-10-2012, 09:20 AM
laxinharley's Avatar
Don't feel bad. Sounds like yours is still working. I broke mine. Had no idea you were supposed to shim it. Oh well live and learn.
laxinharley is offline
post #8 of 19 (permalink) Old 09-10-2012, 10:21 AM Thread Starter
TRUBlue's Avatar
I did too, guess it didn't work so well.
Do you remember what the repair cost was and did you do it or did you have it done?
TRUBlue is offline
post #9 of 19 (permalink) Old 09-10-2012, 11:12 AM
faststan's Avatar
I think H-D price for the switch is about 60. I purchased from Indy for 16.95. You will need to pull the fairing and find the wiring junction and match the colors. I replaced mine when I put on new bars. Before that I used a small sticky 'o' ring with a piece of Gorilla tape on the lever to cause the light to go off so my cruise would work.
faststan is offline
post #10 of 19 (permalink) Old 09-10-2012, 12:45 PM Thread Starter
TRUBlue's Avatar
I think H-D price for the switch is about 60. I purchased from Indy for 16.95. You will need to pull the fairing and find the wiring junction and match the colors...
Pull the fairing to replace a switch in the RH control housing? Man, I hope there's an easier or simpler way than that.
TRUBlue is offline
6th gear only cruise conttol MShell Troubleshooting for Road Glides 10 07-11-2018 09:17 AM
Radio coming through with static... Only sometimes Rasconzo Audio 0 06-23-2015 08:29 AM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
Anybody Switched to Radial Tires? boneman1 Aftermarket Accessories 11 01-13-2012 09:00 AM
Cee bailey 16" dome switched from kw 12" CCRydah Windshields 43 03-24-2011 05:21 PM
