Oem monkey bar install on 2010 roadglide - Road Glide Forums
post #1 of 79 (permalink) Old 09-23-2010, 01:00 AM Thread Starter
Just got my bars today and will be installing soon, do I need tbw extensions? Or any other wire extensions? These are the 10's. Any help would be greatly appreciated.
Garcou is offline
post #2 of 79 (permalink) Old 09-23-2010, 04:13 AM
Freaky's Avatar
no extensions needed. Just lots of patience. Good luck with your install.
Freaky is offline
post #3 of 79 (permalink) Old 09-23-2010, 11:15 AM Thread Starter
Would it help to have extensions?
Shane (From Washington)
2010 Road Glide Custom
Axtell 107 (10.6-1 Compression), Pro Street Heads by Dewey, TMAN 590 cams, S&S Roller Rockers, Woods Directional Lifters, Revolution Performance EMS, D&D Boss Fatcat, HD Heavy Breather, Alpine IDA-305s head unit, Boston Acoustic Pro 60SE Speakers, Alpine PDX 2.150 Amp. 116 HP/128 TQ
Various chrome and black bits......
"I've Got A Cobra Snake As A Necktie"
Garcou is offline
post #4 of 79 (permalink) Old 09-23-2010, 11:25 AM
Freaky's Avatar
I dont think so, but if you PM Neano62 he can give you the wiring breakdown provided by Yaffe if you dont already have it, it's worth it's weight in gold when doing it, because you have to take appart the connectors in order to get the wiring down through the bars and this will help to be sure you get it all back together correctly.
Freaky is offline
post #5 of 79 (permalink) Old 09-23-2010, 05:38 PM
just wrapping up my 12" monkey bars. what a pain on my 09. it can be done. Neanos directions are key. also lots of EZ pull
quato102 is offline
post #6 of 79 (permalink) Old 09-23-2010, 05:48 PM
NakedSnowman's Avatar
Got mine as well....Got a chubby when FedUp showed...
NakedSnowman is offline
post #7 of 79 (permalink) Old 09-23-2010, 09:31 PM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
Quato- What did you need for the 12s?
CustomGlide is offline
post #8 of 79 (permalink) Old 09-23-2010, 09:44 PM
mick14's Avatar
Are you guys using one piece of heat shrink? Where do you get it? I can only find it in lengths of 6" or so. I have the tbw through but can't get the other wires through on the right side. What have you guys been using to hook and pull the wires through with? I also used heat shrink of shorter lengths butted up to each other on the control wires but didn't use any on the tbw. Should I? Any help is appreciated. This is a pta. Thanks.
mick14 is offline
post #9 of 79 (permalink) Old 09-23-2010, 11:05 PM
Neano62's Avatar
I used Petroleum Jelly! (Vasoline) for lube, kept all the original black stock wrap on the wires intact. Ya grease m up good enough they'll slide.
[/IMG]
Neano62 is offline
post #10 of 79 (permalink) Old 09-24-2010, 08:52 AM
mick14's Avatar
Thanks Neano,
What did you use to fish the wire through? I used a shoe lace with a fishing sinker for the throttle by wire but, there has to be something better.
mick14 is offline
Yaffe OEM Monkey Bar Install 07 RG johnnycatmusic Controls & Handlebars 2 09-25-2016 04:44 AM
Paul Yaffe OEM Monkey Bars v. Monkey Bagger Bars Fahred Controls & Handlebars 14 08-27-2013 09:39 AM
Yaffe OEM Monkey Bar install issues RGCBandit Controls & Handlebars 5 09-08-2012 09:37 PM
Yaffe OEM Monkey Bar questions... RGCBandit Controls & Handlebars 16 08-27-2012 09:21 PM
PYO Monkey Baggers vs. Monkey OEM?? Ptl203 Controls & Handlebars 16 08-07-2010 08:04 PM
