Help with choosing the wright bars - Road Glide Forums
post #1 of 5 (permalink) Old 10-27-2012, 07:09 PM Thread Starter
hittman's Avatar
This may have been answered before but I could not find anything.
I would like to buy new handle bars that are no higher than stock. They could even be a little lower.
They would need to be around 2" - 3" closer to the rider.
I do not want to change the length of any cables if I can keep from it.
My ride is a 2013 RGC.
Would anyone have any suggestions?
Thanks in advance.
hittman is offline
post #2 of 5 (permalink) Old 10-27-2012, 07:16 PM
neuropac's Avatar
Look at the relaxor bars by ballistic cycles the are low with more pullback, there is a few bike on the forum with these bars, I am thinking about selling mine never installed chrome still in box going another direction, pm me if you think you would be interested thanks Chris. They are 1.25 in in diameter, drilled for internal wiring and will work with throttle by wire.
2011 FLTRX 103
2005 Big Dog Ridgeback
1982 FXR Superglide 1340 shovel
neuropac is offline
post #3 of 5 (permalink) Old 10-27-2012, 08:09 PM
FrankieB's Avatar
This is what i suggest for the correct bar. Get someone to staddle the front fender and hold the bike upright with you on it. Then you close your eyes and lift your arms up 4 or 5 times, measure that location. By cloing your eyes and lifting your arms automaticly, you should be in the most natual position, which is usually the most comfortable.
06 RK
11 RGU
FrankieB is offline
post #4 of 5 (permalink) Old 10-27-2012, 08:16 PM
eme56's Avatar
+1 on the advise on finding the correct bar position. I would suggest that you make sure you have the right seat before doing the bars. I did the seat first, and then found the Krome Werks Heritage +2 bars were perfect. These together made a world of difference.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #5 of 5 (permalink) Old 10-27-2012, 09:23 PM
++1 on that advice but finding the "perfect" bars is probably one of the most difficult things to do for the scoot. Its a very subjective question. What works for others may not work for you. Keep in mind that all the bars companies out there seem to measure their bars in a different manor. IMO the method posted before is probably the best way to get an idea of where to start. Sit on bike with bars you may be interested in as this will give you an idea as well. Seat position is also a factor. Good luck in the search
Ride wright wheel bigmatt1967 Wheels and Tires 6 06-02-2016 05:42 PM
dna vs. ride wright vs. sinister 2012fatso Wheels and Tires 6 07-01-2014 10:42 PM
Need help choosing bars houston Controls & Handlebars 11 02-14-2014 11:42 PM
need help choosing bars greenenvey Controls & Handlebars 3 02-16-2013 06:04 AM
help choosing a cam for my 02 jdh3378 Engine Related 4 01-31-2011 07:50 AM
