Adjusting shifter... - Road Glide Forums
post #1 of 15 (permalink) Old 10-27-2012, 09:58 PM Thread Starter
bikerglasses's Avatar
Its been a while, but correct me if I'm wrong the shift linkages are adjustable ? My shifter is too close to floorboard, I'd like some more room under it.
Also, any suggestions on new brake lever ? I'd like one where I can put my foot under it and use the floorboards... I don't have huge feet, so the big guys must have even more of a problem.
Sent from my SCH-I535 using Motorcycle.com Free App
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
post #2 of 15 (permalink) Old 10-27-2012, 10:28 PM
staush's Avatar
Take the bolts off, front and back. Mark where the shifters are at. Slide off and move up one or two splines. Put back and your ready to go.
staush is offline
post #3 of 15 (permalink) Old 10-27-2012, 10:35 PM
idahointrudr's Avatar
I adjusted my shifter up. Removed the back part of the shifter so I could slid my foot back there. I cut my brake pedal in half. Now I can slide my foot forward on that side.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #4 of 15 (permalink) Old 10-27-2012, 11:55 PM Thread Starter
Hmm any pics of brake pedal?
post #5 of 15 (permalink) Old 10-28-2012, 12:00 AM Thread Starter
Here's a pic of my old softy...
Oops this was supposed to go to my new user intro post ...if someone can move it.
post #6 of 15 (permalink) Old 10-28-2012, 08:13 AM
bucketlisthd's Avatar
I recently stripped the front shift lever 60 miles from home on back roads. (lotsa shifting) I managed to get home using the rear lever for both up & down shifts.
Woulda been tough with only one lever. I use the rear lever exclusively for upshifts anyhow, so it's stayin'.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #7 of 15 (permalink) Old 10-28-2012, 08:33 AM
Torquey's Avatar
Your question has already been answered, but you can consider these (relatively expensive) alternatives from Battistinis, the extended shift levers and brake pedal, which gives much more room around and under the pedals. I have never felt as comfortable a set up. HD makes extended billet shift levers for a bit less $, and inexpensive ones can be found on eBay, but I don't trust the build quality of these brand X items. The Battistinis stuff could be used in bridge construction, yet are very light.
Torquey is offline
post #8 of 15 (permalink) Old 10-28-2012, 09:22 AM
BDMastiff's Avatar
Also, the bolts are friggin' tight and easy to strip if you don't use your tools properly. The top bolt is easy but the bottom one can be a pain.
1996 Fatboy
BDMastiff is offline
post #9 of 15 (permalink) Old 10-28-2012, 09:37 AM
You can also loosen the jam nuts on the shifter rod and make a couple turns to raise or lower the shifter. Where the shift pedal goes through the primary its just a pivot point.
post #10 of 15 (permalink) Old 10-28-2012, 08:08 PM
Here you go.
Adjusting Speedo with Power Vision uhpilot ECM/Fuel Management systems 18 06-05-2013 11:21 AM
Adjusting the 500W Amp JayKS J&M 2 02-07-2013 08:40 AM
Adjusting a J&M 250 watt amp ironmark J&M 8 05-25-2012 11:10 AM
adjusting stock backrest opr1945 Seating: seats, backrests 2 04-02-2012 09:07 AM
Adjusting Headlamp Assembly Hotroadking Lighting 0 06-28-2011 01:12 PM
