Help needed. How to install Grips - Road Glide Forums
post #1 of 10 (permalink) Old 10-28-2012, 01:49 PM Thread Starter
Still Grumpy's Avatar
Im a little reluctant to do this on my own .
I' ve never changed grips and with the TBW im even more reluctant to do it. Ive seen You Tube vids showing how to do it and it seems simple enough but it wasn't with the Throttle by wire .
Does anyone have a link on how to do this. ?
Thanks.!
Still Grumpy is offline
post #2 of 10 (permalink) Old 10-28-2012, 02:19 PM
Redfish-Joe's Avatar
The throttle grip just slips over the grooves in the rheostat for the throttle. No problem. Just be careful with the front brake switch and the clutch switch. Other that that the hardest part will be getting your old left grip off.
Redfish-Joe is offline
post #3 of 10 (permalink) Old 10-28-2012, 09:21 PM
TRUBlue's Avatar
+1 to what Joe said, be careful with that switch. The manual says use cardboard as a shim to hold the lever, I used the head of a zip tie. I didn't have a problem with the LH side but no adhesive was used, it came right off.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #4 of 10 (permalink) Old 10-29-2012, 06:51 AM
bucketlisthd's Avatar
I used soapy water to secure my left grip on my wing. Surprisingly, it worked great.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #5 of 10 (permalink) Old 10-29-2012, 09:50 AM
Just watch the brake light switch on the right side and the clutch safety switch on the left side. I never used anything like cardboard to protect the switches but it is not a bad idea. The HD grips have a male part on them that fits into the female groove in the switch housings that way the grips will stay in place without any adhesive because the grip is married to the switch housing. The install is simple just make sure that you do not pinch the wire harness when tightening the clutch & brake lever clamps .
post #6 of 10 (permalink) Old 10-29-2012, 10:59 AM
rageglide's Avatar
Remove the left grip by loosening the switch housing.
Gently slide a slim screwdriver about half way,
Give a squirt of windex in the opening you created.
Leave screwdriver in place and start twisting back and forth at the open end. You'll feel the windex start working it's way around and the grip will let loose... works great, fast and not messy.
rageglide is offline
post #7 of 10 (permalink) Old 10-29-2012, 11:35 AM
You don't need to do that with the HD grips. HD does not use any adhesives on the grips all you need to do is take the switch housing apart and slide the grips off the handlebars. Be careful the left grip may slide off and land on your foot so get a hold of it.
post #8 of 10 (permalink) Old 10-29-2012, 11:46 AM
rageglide's Avatar
Then this is new... my '05 had the captive left grip and it was adhered to the bar.
Also, what's this you say about a clutch interlock switch... I have no such thing on my '12.
post #9 of 10 (permalink) Old 10-29-2012, 05:53 PM
Sure you have the clutch interlock switch (my 08 fltr has it) that is why your bike will not start in gear unless the clutch is pulled in. If your bike starts in gear without the clutch pulled in then the interlock switch is broken or not installed properly. You can see in the lower half of the clutch side switch housing were the grip sets into the housing.
post #10 of 10 (permalink) Old 10-29-2012, 10:50 PM
rageglide's Avatar
Well, I'll be a monkey's uncle. Popped it apart and there it is. Dang, one step closer to a ricer... lol When did this get added?
2016 RG West Coast MX T bars install help needed ! wheredugo Controls & Handlebars 13 03-30-2017 07:09 PM
Help New bar install with heated grips sometimer Controls & Handlebars 5 07-12-2014 09:43 PM
Rear Fender Install. HELP NEEDED HUTMO Paint & Bodywork Section 8 02-11-2013 08:37 AM
Help needed with wo517 install RandyM Controls & Handlebars 1 06-17-2012 07:02 PM
Install help/list needed oc357 Audio 0 09-12-2011 07:30 PM
