Handlebar adjustment?? - Road Glide Forums
post #1 of 8 (permalink) Old 10-06-2010, 04:56 AM Thread Starter
bagger51's Avatar
I have a 2010 RG that I think if I could just adjust the handlebars back a 1/2 " or maybe an inch that they would be more comfortable. At this point I don't want to replace them. Do I have to go through the fairing removal process just to adjust them? Yikes!
2010 FLTRX
MODS-Windshield, Heritage Bars, Sundowner seat, Pegs, Driver Back rest, Passenger Back rest, HD Lowers, Rinehart Xtreme True Duals
bagger51 is offline
post #2 of 8 (permalink) Old 10-06-2010, 05:10 AM
No, I hope you have a service manual for your bike if not you can do the adjustment fairly easy. On each side of your speedo housing are two screws, I think they are torx style you need to remove. Unclip the plastic tabs that hold the speedo in the housing and lift up, unplug the cables and sit it aside.
You know have access to two of the handlebar chinch bolts, loosen the two that are exposed and make you adjustment. Don't loosen them too much just enough so you can move your bars, tighten the bolts and check to see if you have your bars adjusted where you want them. Then just reverse the proceedure. You don't have to unplug the speedo/tach it has enough slack to move it out of the way, and you can wrap it in a towel or have someone hold it, but it was easier for me to just unplug it. After your done you might have to readjust your control switches on each side which is also very simple to make them fit your riding style and your comfort zone, just a couple of torx screws on either side of the controls and the lever perches.....
Good Luck and buy yourself a service manual
twowheel99 is offline
post #3 of 8 (permalink) Old 10-06-2010, 05:16 AM Thread Starter
bagger51's Avatar
Sweeeet! Just what I was looking for. Manual is on my list. Thanks.
2010 FLTRX
bagger51 is offline
post #4 of 8 (permalink) Old 10-06-2010, 10:48 AM
It takes like 5 minutes to adjust
Shane (From Washington)
2010 Road Glide Custom
Axtell 107 (10.6-1 Compression), Pro Street Heads by Dewey, TMAN 590 cams, S&S Roller Rockers, Woods Directional Lifters, Revolution Performance EMS, D&D Boss Fatcat, HD Heavy Breather, Alpine IDA-305s head unit, Boston Acoustic Pro 60SE Speakers, Alpine PDX 2.150 Amp. 116 HP/128 TQ
Various chrome and black bits......
"I've Got A Cobra Snake As A Necktie"
Garcou is offline
post #5 of 8 (permalink) Old 11-17-2010, 10:32 AM
handlebar adjustment
I just picked up my Triple Red, 2000 SE Road Glide last nite. We put new Paucho bars on it. However, they adjusted the bars way to far forward. I haven't had a chance to check the manual. Do you know if this would be the same procedure. I need to pull mine back about 3 inches.
Thanx for the help
2bb
dr. g
2blackbelts is offline
post #6 of 8 (permalink) Old 11-17-2010, 01:42 PM
CHAINSAW's Avatar
yup, same procedure.
Such is the rule of honor.
CHAINSAW is offline
post #7 of 8 (permalink) Old 11-21-2010, 06:57 PM
Thanks Chainsaw. I adjusted the bars in five minutes. It took longer to find the right tools then do the adjustment.
2 bb
post #8 of 8 (permalink) Old 05-03-2014, 03:14 PM
Just sold my 08 Street Glide a purchased a 2013 Shark. What a difference! I love it but on my first ride I determined the bars were just a bit too far forward for me. A quick search on this forum and bingo! Thanks for the easy directions. A service manual is definitely in order.
maineiac-moto is offline
2017 RGS handlebar adjustment? thereal142 Controls & Handlebars 8 03-24-2018 09:19 AM
Handlebar adjustment questions. Oldbie Controls & Handlebars 3 09-05-2017 05:05 PM
Rushmore Handlebar Adjustment KevDillow Do-IT-Yourself 13 05-04-2017 09:01 AM
Headlight adjustment. tourglide Do-IT-Yourself 12 08-08-2013 09:07 PM
Clutch adjustment longrides Do-IT-Yourself 5 09-23-2010 10:51 AM
