throttle by wire harness ???? - Road Glide Forums
post #1 of 16 (permalink) Old 10-08-2010, 12:04 AM Thread Starter
Just got my Monkey bars wired through and I have a puzzle about the two pin AMP connector off of the throttle harness.
I cant find or remember where this dumb little bugger connects to. HELP!!!
Also, I had a bastard of a time releasing the pins from this connector and have another set of bars to do this fall. Any help here would be appreciated as well.
2010 roadglide custom, 10" monkeys, 8" windvest, 7.25 J&M, 200w bazooka, Iron Aces mount, Danny Gray Air Hawk, Vance & Hines Big Radius, TTS, SE forced air, SE 255 cams, pushrods, roller rockers, this and that...
flatblackbastard is offline
post #2 of 16 (permalink) Old 10-08-2010, 12:47 AM
NakedSnowman's Avatar
At the END under the fairing?
NakedSnowman is offline
post #3 of 16 (permalink) Old 10-08-2010, 12:51 AM Thread Starter
I think so, its a little black plastic two pin AMP connector and I cant find anything to plug it back in to.
post #4 of 16 (permalink) Old 10-08-2010, 12:57 AM
Busting out my manual on CD for a pic....gimme a few min.
post #5 of 16 (permalink) Old 10-08-2010, 12:59 AM Thread Starter
new bike, no manual yet. I sure appreciate this right now!!!
post #6 of 16 (permalink) Old 10-08-2010, 01:10 AM
I've got a 2010...All the same....Ok, Can't use the pic in the manual..It's a StreetGlide example, but it's very similar. From memory...It should be hanging just under the radio mount. You have your black and grey connectors which are your switch housing wires, and the 1 plug should be right in the middle under the radio or just to the left if you are facing the front of the bike.
I have a loose connection on my volume and track selection, so my nose will be coming off tomorrow...If you still need help, I'll have a PIC of mine for you.
post #7 of 16 (permalink) Old 10-08-2010, 01:19 AM Thread Starter
I sure do appreciate you getting out the manual for me. Still not finding the little bugger, but I'm sure I get it eventually.....or set it on all on fire! Thank you!!!!
post #8 of 16 (permalink) Old 10-08-2010, 12:41 PM Thread Starter
still no worky. everything is back together and functional except throttle. Two pin AMP with a black wire, and a white wire.
post #9 of 16 (permalink) Old 10-08-2010, 02:10 PM Thread Starter
might be for heated grips ....
post #10 of 16 (permalink) Old 10-08-2010, 11:42 PM
Ducflames904's Avatar
I have the 11 service manual and just did my bars. That two prong is for heated grips. It doesn't connect to anything.
Ducflames904 is offline
09-10-11 Fairing Wire Harness Differences robertg Troubleshooting for Road Glides 4 10-18-2014 10:31 PM
2 wire harness under left side cover? ddaarr *General Road Glide Discussions/Pictures 2 04-19-2011 12:50 PM
Rear wire harness for Stop, Turn, Brake Seven3smoke *General Road Glide Discussions/Pictures 9 03-02-2011 04:40 PM
Added wire harness for rear speakers- It's a bitch! BDMastiff *General Road Glide Discussions/Pictures 8 08-29-2010 08:50 PM
Wire Harness audio overlay BDMastiff Aftermarket Accessories 3 08-14-2010 09:17 AM
