12" or Taller Bars Checklist - Road Glide Forums
post #1 of 18 (permalink) Old 10-09-2010, 09:35 PM Thread Starter
CustomGlide's Avatar
Send a message via AIM to CustomGlide
Wanted to make a checklist of things needed or to simply make things easier for installing bars that require new cables and/or wires. Just a quick reference for us that want to install , and dont want to check several different threads. Please add anything that you can think of. Things that I can think of are:
1) Extended cables and wires
2) Heat shrink
3) Small chain to pull wires through
4) Lube to help wires slide through
CustomGlide is offline
post #2 of 18 (permalink) Old 10-09-2010, 09:56 PM
Ducflames904's Avatar
I have 12" Wild 1 Outlaws on my 2011 RGC and used all stock cables and wires. Fit great. The throttle harness just made it and clutch and brake were close. Control wires had room to spare. Just used a piece of wire to pull a string through. Then used string with electrical tape to pull wires through. Pretty easy.
Ducflames904 is offline
post #3 of 18 (permalink) Old 10-09-2010, 11:30 PM
Rowdy's Avatar
2) Heat shrink
Don't forget the manual... Pretty handy to have for a job like this. There is also info on the DIY thread.
Rowdy is offline
post #4 of 18 (permalink) Old 10-11-2010, 07:20 AM
ncbeast's Avatar
Ducflames, do have some pics of your 12's? Looked on their site and $219 is a good price...I know they have 8" pullback but how muh more is that compaired to stock?
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #5 of 18 (permalink) Old 12-07-2010, 10:47 PM
Did you see my pics ? They are on the Wild1 web site. Check it out. http://www.wild1inc.com/612Bmw.html
post #6 of 18 (permalink) Old 12-08-2010, 06:59 AM
ncbeast's Avatar
Yeah, those look great and I bet they are easier to wire than the Monkeys.
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #7 of 18 (permalink) Old 12-08-2010, 09:52 AM
Tinker1950
Guest
Posts: n/a
Great looking bars............I want..........
post #8 of 18 (permalink) Old 12-10-2010, 01:10 PM
All you need
You do not need to extend your wires, You can use your Stock wrap. You can keep clutch and brake line Just take clutch from center of forks to side, for your brake line cut the zip tie and let it run freely. NOTE: I do plan on extending the clutch and brake line, I just didn't feel up to pulling exhaust and tank right now. If ya want it all to run easier get your wife or someone to help you feed as you pull, I ran the TBW first. Take your time and I prayed first; and come to think of it, I prayed through it all. Good luck and have fun.
Frodoe is offline
post #9 of 18 (permalink) Old 12-24-2010, 12:57 AM
Tek74's Avatar
Comfort Factor?
The 12's really do look great. Probably the perfect height for me at 6ft tall. I may wanna do some mini apes in future, but fear the long distance comfort factor. To you and any others who have ridden with 12's, how long can you ride with them? Is there noticeably more arm/shoulder fatigue? Some 10's would proabably be better for me, but that's not much taller than the stock bars......
Tek74 is offline
post #10 of 18 (permalink) Old 12-24-2010, 06:00 AM
btfochad's Avatar
new poly bushings are needed...i'm in the middle of putting 14" chubby's on mine and the weather in virginia has been to damn cold to get in the garage. i actually bought the yaffe kit and it had everything i needed.
btfochad is offline
Looking for service checklist for a 2017! Cbordies Do-IT-Yourself 4 05-28-2017 09:57 PM
Motorcycle Safety Checklist eagledax Active Military and Veteran's group 4 05-01-2014 12:03 PM
It is now 12:12 12-12-12!!! Garemlin General Off-Topic Discussions 10 12-12-2012 09:45 PM
Trade for taller yaffe bars? 2010fltrx Controls & Handlebars 0 06-02-2011 06:37 PM
