Running internal wires - Road Glide Forums
post #1 of 6 (permalink) Old 12-08-2012, 10:51 PM Thread Starter
hamer007's Avatar
Anyone have a good link or is there a sticky on how to attach your wires to the chain in order to run the wires internally through bars that have 90 degree bends???? Donk 's Sticky is great however it doesn't tackle this part.
2012 RGU Black,8 inch Klockwerks windshield,
Power Commander V,Vance&Hines Power Duals w/ high Outputs, Screaming Eagle High flow A/C,
PYO 10 inch Monkee Bars and alot of Wille G Skulls
hamer007 is offline
post #2 of 6 (permalink) Old 12-09-2012, 08:27 AM
TitusPollo's Avatar
I would try electrical tape. Make sure you pull it tight (even stretching a little) as your wrapping the wire bundle and chain together. You would probably want the chain overlapping the wire harness a couple inches. This way you have 2" worth of tape holding it together as you pull. (the 2" is just a guess, ya might get by with less or you might need more).
2012 RG ULTRA - V&H Slip-Ons - 14" Santee apes & a decatted head pipe
TitusPollo is offline
post #3 of 6 (permalink) Old 12-09-2012, 09:26 AM
HD_Shock's Avatar
I used a longish piece of shrink tubing over the wire bundle and shrunk it tight beginning well below the pins. I then folded the excess back down (leaving a (loop"), to where the tubing was started and taped the crap out of it so it was nice and tight. That gave me nice pull point from the center of the bundle. Then it was a simple matter of attaching the chain to the shrink tube "fold" with some wire. (hope that makes sense).
It's important to NOT pull from the pin location as they can easily be broken or bent.
-phil
2011 FLTRX 103
HD_Shock is offline
post #4 of 6 (permalink) Old 12-09-2012, 10:40 AM
Shrug's Avatar
Send a message via Yahoo to Shrug
Just did this on my SG. The key is to stagger the ends of the wire bundle about 1" each so you're not tugging a lump through the bend. Push from one end as you pull from the other. It should work.
When my cable techs have a tight multiline pull through a full pipe with a 90 degree bend, they sometimes grease the wires.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #5 of 6 (permalink) Old 12-09-2012, 03:01 PM Thread Starter
hamer007's Avatar
Thanks,, appreciate it, when I get these Yaffe's i'll just make sure that I make it a whole day project and send the wife to the mall, they always have a way of breaking the creative cycle, I just stained the deck for her so should keep her off my back for a minute so I can indulge in one of my personal projects, LOL
hamer007 is offline
post #6 of 6 (permalink) Old 12-09-2012, 03:15 PM
Ranger75's Avatar
I ended up running the wires a couple at a time and using weed wacker string taped at least 8" with plenty of windex as wire lube. Stay persistent and it'll work, just pretty frustrating.
Be polite, be professional, but have a plan to kill everyone you meet.
Ranger75 is offline
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
help with right side radio button (internal wires) Dmize Controls & Handlebars 0 01-19-2013 06:04 PM
Trouble running internal wiring with TBW MOSPORTSTER Controls & Handlebars 16 02-26-2012 01:12 PM
running amp power wires spender9 Audio 5 06-03-2011 07:37 PM
Running wires internally on Heritage bars x52gnr Controls & Handlebars 3 04-22-2011 11:53 AM
